pulley question
Old Nov 16, 2007 | 01:15 PM
worldtraveler's Avatar
worldtraveler
From: Proud dad of 2 responsible adults and 1 fallen warrior txtx
Default pulley question
Does installing an undrive pulley affect the electrical system at all? Insufficient charging or anything like that?
Old Nov 16, 2007 | 02:48 PM
Sleazy Rider's Avatar
Sleazy Rider
Veteran: Marine Corps
a corvette tech told me that i would have charging problems with an underdrive pully on a street car. i went with the standard size fluidamper. i'm sure that there will be members say they have no problems with an underdrive pully on the street, but i wanted to stay on the safe side.
Old Nov 16, 2007 | 02:57 PM
road dog's Avatar
road dog
I got one on mine and the car run smoother than the stock one and no problems at all use an arp bolt once you change it your not going to want to do it again
Old Nov 19, 2007 | 11:21 AM
bucwheat's Avatar
bucwheat
Old Nov 19, 2007 | 12:03 PM
flatbush862's Avatar
flatbush862
Default Under drive pulleys and emissions
With a 3 peice st (ie. March) on a 1990 L98 -
- Will the air pump be turning slower and subsequently will the emissions be effected? I live in NY State
Also - on the the 3 peice set - will another serpentine belt be required - other than stock length?
Old Nov 19, 2007 | 02:10 PM
Last C5's Avatar
Last C5
Your air pump is electric and if NY is plugging into the OBD reader only then you can totally remove it, have it tuned out so you don't get codes, and you're good to go. My understanding is that the air pump only activates during startup/warmup.
Old Nov 19, 2007 | 05:36 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
I've been running a 25% underdrive pulley for the past year, no charging problems at all.
Old Nov 19, 2007 | 06:29 PM
BitViper's Avatar
BitViper
ditto on my Camaro....and if your do have problems...you can generallly get an OVERDRIVE pully for you altenator.
People who do have problems are teh ones that have a HUGE amp or other electrical demend going on in the car...most people dont have this problem
To pulley question
