need help on T&D rocker shift
Old Nov 19, 2007 | 09:24 AM
robert miller's Avatar
robert miller
Default need help on T&D rocker shift
Have put the T&D rocker shift on the car. I have got the correct push rods in it. But seems like getting a little more chatter. Anyone out there that has put these on. please some feed back. thanks for the look.
Old Nov 19, 2007 | 11:13 AM
robert miller
Default ttt
need help r feed back
Old Nov 19, 2007 | 12:04 PM
vettenuts's Avatar
vettenuts
Make sure the pushrods are not rubbing against the cylinder head where they come through. I remember reading this can be an issue. If they are, the end of the pushrod may be getting moved around as the valve opens.
Old Nov 19, 2007 | 12:44 PM
zeevette's Avatar
zeevette
WTH's a "rocker shift" ?
Old Nov 19, 2007 | 02:07 PM
vettenuts's Avatar
vettenuts
I assume he either meant "shaft" or the rockers are "shifting".
Old Nov 19, 2007 | 03:03 PM
robert miller
hit diff key,, shaft.still have the chatter....thanks for the post back. talked to them at t&d. said never had a call on the chatter.
Old Nov 19, 2007 | 05:12 PM
Phil97SVT's Avatar
Phil97SVT
Are they adjustable?
Old Nov 19, 2007 | 05:31 PM
robert miller
yes
Old Nov 19, 2007 | 06:43 PM
Phil97SVT's Avatar
Phil97SVT
Originally Posted by robert miller
yes
Ok, how did you adjust them?
To need help on T&D rocker shift
