Sleeving an LS1 block
Old Nov 17, 2007 | 03:50 PM
vetteman9368's Avatar
vetteman9368
From: I have no tolerence for liberals and fools, but sometimes i repeat myself
CI 3-5-7-8-9 Veteran
St. Jude Donor '08
Default Sleeving an LS1 block
Is there any alternative to the darton wet sleeve setup? Or is that the only way to go. I only want to bore it .070 over stock (rules restricted class)
Old Nov 18, 2007 | 10:17 AM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
While an LS-1 can be over bored, .25 mm is all that is recommended (approx .10 inch), you won't get anywhere near .70 before you go thru the liner.
Talk to both MTI racing shops, the one in Atlanta and the one in Houston, both shops done sleeves on the LS-xx blocks.
Old Nov 18, 2007 | 01:02 PM
AU N EGL's Avatar
AU N EGL
Might consider a larger block.
the LS1 block had some minor oiling and cooling issues that were sorted out in the LS6 and LS2 blocks.
Old Nov 18, 2007 | 01:13 PM
lp2k's Avatar
lp2k
agree
Old Nov 18, 2007 | 06:39 PM
vetteman9368
St. Jude Donor '08
rules restricted, has to be an LS1 block
Old Nov 18, 2007 | 07:26 PM
fsuforever's Avatar
fsuforever
What do u have up your sleeve now chad
Old Nov 19, 2007 | 08:13 AM
AU N EGL's Avatar
AU N EGL
the older LS1, not an LS6? Many of the f-body ppl call the blocks LS1, even though they are LS6s.
Which sanctioning body?
Old Nov 19, 2007 | 05:50 PM
vetteman9368
St. Jude Donor '08
i coudl run the LS6, not the LS2. Its NHRA
Old Nov 19, 2007 | 06:12 PM
AU N EGL's Avatar
AU N EGL
if you can run an LS6 and can get one, do it. The oiling and cooling issues around the #7 & #8 cylinders in the block are worth it. Espcilly if your are going to boar out the block
Good Luck on your project
Old Nov 19, 2007 | 08:59 PM
Zozzie's Avatar
Zozzie
I guess so. That's close to 3/4".
Old Nov 19, 2007 | 10:21 PM
vetteman9368
St. Jude Donor '08
that should have been .070
Old Nov 20, 2007 | 02:33 AM
NSTG8R's Avatar
NSTG8R
+1 .. my 03 came with the ls6 block.
thanks gm.
Old Nov 22, 2007 | 06:30 PM
gorillavet's Avatar
gorillavet
If you are going with a sleeved process use ONLY Darton Sleeves. They have had huge success in Drag racing and if they are done by a Darton approved engineering shop you will have a block stronger than any bored out block. Good Luck!
Old Nov 22, 2007 | 09:04 PM
RED99's Avatar
RED99
I would call Katech and talk to them.
To Sleeving an LS1 block
