How do you align the headlight door?
Old Nov 17, 2007 | 09:50 PM
JCSZ51's Avatar
JCSZ51
Cruise-In IX Veteran
Default How do you align the headlight door?
I've done a search and cannot find how to move the door backwards toward the hood. I've looked at it a few times and don't see an adjustment for that movement but I know there is one!!
Anyone help a newbie out?
Old Nov 18, 2007 | 01:24 AM
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
It depends on how much you need to move it. You may have to move the entire assembly forward. Loosten the screws that hold the lid on and there should be a little play in the clips that hold it on. Push the lid forward while you tighten the screws.
Old Nov 18, 2007 | 02:16 AM
DeeGee's Avatar
DeeGee
The cover is held in place by 4 torx screws, 2 at the back and one each side. With the hood up and the lights down take out the rear two screws. Turn on the headlights and back off to the park position to kill the headlights. Loosen the two side screws and adjust the cover to get the fore and aft position correct. Tighten those back up and close the lights to check its correct. If so, refit the rear screws and tighten them back up. If the "up/down" position is out, the little white clips adjust vertically to get a good flush fit.
Old Nov 18, 2007 | 02:52 AM
jdmvette's Avatar
jdmvette
Night Owl for life
here's an awesome post with pics that show how to adjust all the headlamp door gaps:
Originally Posted by NONO5.0
Ok, to fix this:
Adjust these little by little *YOU ADJUST THE TORX HEAD, NOT THE WHITE NUTS:
To fix this:
Adjust these little by little. They will allow you to move the frame side to side and back and fourth:
Just take your time!
For future use, here is a good link for others who may come across this thread:
http://forums.corvetteforum.com/show...headlight+gear
edit---
although i'm not sure why "NONO5.0" mentions not to adjust the white nuts above, i always fiddle with those when i need to make the covers sit flush.
Old Nov 18, 2007 | 06:19 PM
JCSZ51's Avatar
JCSZ51
Wow! now that was more than I was hopping for.
I got it knocked out, took alot more time than I though but I finally got it where I am happy.
Thanks alot!
Old Mar 10, 2011 | 07:55 PM
CuZ06's Avatar
CuZ06
edit---
Sorry to bump an old thread but JDM is right....helped me sit the passenger side cover sit flush...adjusted the front white nuts and now it sits flush
Old Mar 10, 2011 | 08:27 PM
sfc rick's Avatar
sfc rick
This is weird... I just adjusted mine a few minutes ago and then check the forum out and this thread pops up.
To How do you align the headlight door?
