pup cat removal
Old Apr 21, 2008 | 04:07 PM
ALVETTE00's Avatar
ALVETTE00
Originally Posted by jovette
ALL 2000 C5s came with the larger camshaft, but only those targeted for California or NE USA delivery got the pup cats.
cool...i knew from prior discussions pup=hotter cam, but never confirmed this was the case for the entire Y2K run.
Old Apr 21, 2008 | 04:21 PM
Mike Mercury's Avatar
Mike Mercury
Originally Posted by The Wrench
As far as gutting the Pups, you might get a raspy, hissing sound through the exhaust that you can hear in the car. My '87 made that noise when I gutted the pups. Not loud, just raspy and unpleasant.
DG
there's no need to guess... plenty of us here have actually done this mod, and there is no "hissing" sound.
Old Apr 21, 2008 | 07:36 PM
atsugidad's Avatar
atsugidad
The main CATS on my 02 Coupe came apart internally (110K Miles and was throwing codes)
I bought a set of pipes from an 03 Z (without pups) from a forum member. Don't drag so don't know how much difference it made though sounds and feels a little hotter though the Borla Stingers.
Passed Smog with no problem here in San Diego.
Phil
Old Nov 12, 2008 | 02:39 PM
GreenY2k's Avatar
GreenY2k
2nd Gear
Originally Posted by Mike Mercury
I have a TI cat back installed but I am not getting the sound I expected so I am planning to hollow out the precats on my 2000 Vette to get closer to the ZO6 sound but I have a question.
How much ground clearance do you need to get the mid pips off? Can I put the car on ramps or does it need to be higher off the ground?
Thanks,
Curt
Old Nov 12, 2008 | 07:02 PM
The Wrench's Avatar
The Wrench
No problem; if you can get it high enough to get under it, you can get the midpipe off.
Just be sure to unhook the O2 sensors before you drop the pipe.
Here's an interesting suggestion; after you break up the ceramic brick in the pups, some of the junk might go down the pipe and lodge on the front of the main cats. Run a water hose in the opposite end to reverse flush the pipes. i've done this before wilth no ill effects; the cats see water condensation every time the car is cranked, so I can't see how wetting them could hurt them.
DG
