pup cat removal
Old Nov 19, 2007 | 07:42 PM
RespondsWithGif's Avatar
RespondsWithGif
Default pup cat removal
I've searched and couldnt find a definite answer. If I remove the pup cats, will it throw a code on a 2001? Thanks
Old Nov 19, 2007 | 08:32 PM
Vette Ed's Avatar
Vette Ed
CI 4-5-6-7-8-9-10 Veteran
St. Jude Donor '07-'09
No - mine didn't
Old Nov 19, 2007 | 09:00 PM
Mike Mercury's Avatar
Mike Mercury
http://mikemercury.home.att.net/precats.htm
no codes
Old Nov 19, 2007 | 09:13 PM
philsy's Avatar
philsy
removed mine never thru a code.
Old Nov 19, 2007 | 11:26 PM
jeanlucpicard's Avatar
jeanlucpicard
Nope, no codes. Just make certain you hook up the 4 O2 sensors again to throwing avoid a code. The PC does not know if you have 1, 2 or 5 cats.
Old Nov 19, 2007 | 11:40 PM
pewter2165's Avatar
pewter2165
What kinda performance difference will this make?
Old Nov 19, 2007 | 11:55 PM
wamara's Avatar
wamara
Cruise-In II Veteran
I've heard removing the pre-cats is worth about 5 hp. I also remember reading an article regarding a tuner dynoing with hollowed out pre-cats, and that leaving the hollowed-out chamber messed up the exhaust flow and actually cost hp. Ergo, if you're going to do this, remove them completely, not just their guts....
Old Nov 20, 2007 | 09:30 AM
SKF engineer's Avatar
SKF engineer
Having sat through flow dynamics classes I completely understand that the empty shape of the pup cat should disrupt flow through the pipe but I wonder if the disruption is worse than the actual restriction of the cat material itself. Has anyone done flow tests or does anyone have back to back dyno runs with and without pup cats.
I've thought of removing them in the past to get just a little more noise not so much because I was worrying about 5 hp but if it's going to hurt my power numbers then more noise be darned.
Old Nov 20, 2007 | 10:33 AM
Mike Mercury
I hear ya, but in a pressurized setup... where the enlarged pipe is not at the end of the system... there is no "flow distuption". Near equal pressure on both ends of the enlarged section (which happens a few seconds after startup) eliminates any of this theory concern (the theories are not nonsense... but they don't apply here - or it's soooo miniscule that it's a moot point).
And I'm talking about gasses, not heavy liquids.
Old Nov 20, 2007 | 10:34 AM
Gordy M's Avatar
Gordy M
On a Z06, they gained about 2.5 hp from 2001 to 2002 according to the chief engineer on the project. He told us that when the 2002s were introduced. He was talking about where the 20 hp difference came from.
Old Nov 20, 2007 | 11:43 AM
Mike Mercury
Hey thanks. I remember now that the real data was made public about the pup cats.
2.5 hp is not a lot; but I gutted mine for two reasons:
1. to add some depth to the exhaust tone.
2. It was a free mod
3. to give ulcers to the environ-mentalcases who force this craap on us to begin with.
Old Apr 21, 2008 | 11:11 AM
punknponys's Avatar
punknponys
Does my 2000 Vette have those pre-cats?
Old Apr 21, 2008 | 12:33 PM
Mike Mercury
post #3 links to a web page with a pic you can compare yours too.
In 2001, all C5's had them. Starting 2002 they were on all C5's - except the Z06.
Before 2001 they were installed on some C5's destined to be delivered in certain areas of the country. So, it's hit/miss; best way to determine is through a visual inspection.
Old Apr 21, 2008 | 01:25 PM
dieseldave56's Avatar
dieseldave56
Default swapped exhaust to '02 Z
The answer to your initial question is No to throwing codes.
But because of the possible problems with flow disruptions and exhaust tone I opted to swap out the entire '01 Z for an '02 Z exhaust for $350.
From 1997 to 2000 just the California destined cars had 'pups' to meet CARBs LEV standard. This in fact reduced advertized HP by approx 5 horsepower in California cars. In 2001 the Californai Z06 also had 'pups'.
The 2002 model year brought out the new primary one (1) brick CAT design which meant that the 'pup's and the old two (2) brick CATs could be dropped for a reduction in back pressure ( 2 inches of mercury drop) and an increase of approx 5 hp.
The addition of the larger opening on the fresh air intake box and descreening MAF brought another 5 hp.
Old Apr 21, 2008 | 02:01 PM
Mike Mercury
but is there any measured and documented "flow disruptions " when gutting the pup cats ?
I've been running my 2002 coupe for 5 years with the pup-cats gutted; and people are still amazed at my 1/4 times - compared to my small list of mods.
The 2002 model year brought out the new primary one (1) brick CAT design ...
on the Z06 only
clarified incase someone reads that wrong.
Old Apr 21, 2008 | 02:28 PM
jovette's Avatar
jovette
Fact is that ONLY the 2000 C5 targeted for California or Northeastern USA Sale / Delivery were fitted with the pup cats. All other 2000 C5s, like mine, did NOT have pup cats. No pup cats at all, on pre-2000 C5s.
Old Apr 21, 2008 | 02:44 PM
ALVETTE00's Avatar
ALVETTE00
In Y2K if the car had the pup cats, it also came with a slightly more aggressive cam to offset the lack in hp.
To pup cat removal
Old Apr 21, 2008 | 03:15 PM
jovette's Avatar
jovette
ALL 2000 C5s came with the larger camshaft, but only those targeted for California or NE USA delivery got the pup cats.
Old Apr 21, 2008 | 03:55 PM
Mike Mercury
interesting.
I looked at my GM parts list and they show one camshaft part-number for all 2000 C5's.
ding... ding... ding; we have a winner !
Old Apr 21, 2008 | 04:01 PM
The Wrench's Avatar
The Wrench
Jovette, right you are. The 2000 48-state had no pups, but had the
.500-lift cam. I went to a lot of dyno days with my Texas 2000, and these 2000's routinely dyno'd a few HP more than the '98,'99's.
If you can find a used 2000 48-state midpipe, it will bolt right on
the later years, just like a '02-'04 Z will.
As far as gutting the Pups, you might get a raspy, hissing sound through the exhaust that you can hear in the car. My '87 made that noise when I gutted the pups. Not loud, just raspy and unpleasant.
DG
