Horrible MPG! What Gives? :(
which to me seems like sh*t. There was a past history code of P0171 (Fuel system lean) don't know if that means anything. There is a service vechicle light if that might be connected to something releating to consumption of fuel but I don't know and have to take it in for that.
maybe try to get those cleaned and adjust your driving habits
hope this helps, i can get a full tank to last me 420 miles give or take (evening commute in traffic kills me)
<1999 corvette coupe
my .02 cents!
So, check for exhaust leaks as a starting point.
HTH, and have a Happy Thanksgiving!
Mike
http://www.corvetteactioncenter.com/...9/99specs.html
plugs and wires seem fine... air filter is good but dunno about the fuel filter... and then could you possibly post a pic of the "flex line" showing how it's supposed to be connected?
which to me seems like sh*t. There was a past history code of P0171 (Fuel system lean) don't know if that means anything. There is a service vechicle light if that might be connected to something releating to consumption of fuel but I don't know and have to take it in for that.First of,, we need to know what modifications that have been done to the car. Second, yep, DTC that are present are a MUST!
Please list all the mods that have been done to the engine, last time the car was serviced/tuned up and and DTC.
This is the absolute best C5 Diagnostic Trouble Code (DTC) web site!!!
http://www.corvettedoctor.com/Code_Main.html
Go to “technical data base” and then to “Corvette ECM Computer Codes”. Then select your year car. Read the instructions and then scroll down to the "READ MORE" window to view the code definitions.\
Here is another very good site:
http://www.obd-codes.com/trouble_cod...d-ii-codes.php
or
http://www.gearchatter.com/index.php
Look under LS1/LS6 DTC Codes for you year C5!
Make sure to include the H or C suffix!!
BC
Even our heads/cam cars get 24-28 & a cam only MN6 will get 30-32 with the right tune (and our 1,000 RWHP twin turbo gets app 7-8
secondly... I HAVE NO CODES! No check engine light. The car was just at GM to get rid of the code P0154 O2 Sensor CKT No Activity (Bank 2 Sensor 1) and few other things because the PCM I suppose had to be reset or something. Anyways I have no clue and am so lost. I do have a "Service Vehicle Soon Light" on that I need to get taken back in to have checked out.
If you guys don't believe me that I have no codes heres the DIC lookup:
10-PCM No Codes
28-TCS 5 Codes - C1221 H, C1222 H, C1255 H, C1282 H, C1288 H
40-BCM No Codes
58-SDM No Codes
60-IPC No Codes
80-Radio No comm.
B0-RFA 3 Codes - U1096 H, U1064 H, U1016 H
I have no clue what would be causing me to be getting 160 miles per tank
The DIC reads 20~24mpg while driving but thats definetly off
(actually wish I was getting even that)
Do you ever feel any cylinder misses OR do you ever see the check engine light falsh at you while your driving the car?? Cylinder misfires can be detected by observing the check engine light. If it is flashing, it is detecting a misfire.
Clean the MAF by spraying the MAF wires inside the MAF with MAF cleaner. I have used "brake parts cleaner" with good success!
If you clean your MAF and dont have any current DTC's or misfires,,,,,
Im lost ( and that is RARE). How are you reading your DTCs??
BC
BC
...anyways I'm reading the DTC's just like everyone else... i just pulled them up for you guys in the previous post. just ran through them again to just double check and those are the same historic codes or no codes that came up
RrCox22, are you smelling any gas leaking? When you fill back up, how much is going into the tank? It holds 19.3 gallons bone dry empty to full.
and I haven't filled her up all the way ever since I've had the car (3 months) with gas $3.80 a gallon out here in Cali... just too much on the wallet at a time
...I'm going to Vegas for the weekend and will clean the MAF and Blackwing early next week but for the meantime I'm lost as I don't think that will help much
