New HID lights
Old Nov 21, 2007 | 10:18 AM
dbfrdan's Avatar
dbfrdan
Default New HID lights
I just installed Reuss HID Xenon lights on my 02 C5. The lights work and look great, but now the light covers won't flip back down when I turn the lights off. Any advise is appreciated.
Old Nov 21, 2007 | 10:20 AM
PFMC3's Avatar
PFMC3
Has to do with current draw flip high beams on and turn lights off with highs on.
Headlight module thinks there is a falt in the lighting system.
Old Nov 21, 2007 | 10:47 AM
04 commemorative's Avatar
04 commemorative
St. Jude Donor '17
Ever since I ...well my son put the HID'S in my vette when I am going to shut lights off I need to do it in two steps. One click at a time,if I just turn the control fast to off the lights go off but they stay up.
Old Nov 21, 2007 | 11:18 AM
eric04's Avatar
eric04
just install a 50watt 5 ohm resistor inbetween the car harness and the ballast or if you use a ralay harness put it between the car harness and the relay harness this will fix the problem. PS dont attach the resistor to anything plastic as it gets very hot like a bulb and will melt things i mounted mine to the frame,
Old Jan 19, 2008 | 09:08 PM
joe3451's Avatar
joe3451
St. Jude Donor '09
Default Fix for hid lights
Try my post on this problem, got alot of feedback on this it works great!!!!
http://forums.corvetteforum.com/show...ht=hid+install
Old Jan 19, 2008 | 10:13 PM
Got uid0's Avatar
Got uid0
St. Jude Donor '17
sounds like a fire hazard to me
Old Jan 20, 2008 | 01:10 PM
joe3451's Avatar
joe3451
St. Jude Donor '09
Default Hid
C'mon its an 8 watt bulb, getting plenty of feedback and all good,
Old Jan 20, 2008 | 06:50 PM
tarheeljww's Avatar
tarheeljww
Is this a common problem with all these HID lighting systems?/?? as I was looking at a Galaxy system for my low beams.....
Hope this isn't considered a highjack......
Thanks,
Jw
Old Jan 20, 2008 | 08:53 PM
catch06's Avatar
catch06
I used the same or similar system as Junkman2008, he has a fantastic thread on the install by the way...the only problem I had was forgetting to upgrade the fuse...no issues at all with lamps not closing, etc...
Old Jan 20, 2008 | 11:32 PM
LoneStarFRC's Avatar
LoneStarFRC
Thanks,
Jw
No. My ACA HID set-up works just fine.
Old Jan 21, 2008 | 12:07 AM
FUN LS1's Avatar
FUN LS1
I just bought the $229 kit and no problems here.
Old Jan 21, 2008 | 07:36 PM
spiral04's Avatar
spiral04
To New HID lights
