coras
Old Nov 29, 2007 | 04:02 PM
johnnied's Avatar
johnnied
their were 4 slots cut around the inside of the inside pipe around the diameter were the exhaust pipe goes in. I already have mine back on or I would take a picture. You can see them, their not far inside.
Old Nov 29, 2007 | 04:06 PM
uracowman's Avatar
uracowman
Originally Posted by Toque
So its just a small round piece of exhaust tubing that will essentially close off the passages to the "reflective sound cancellation" area of the muffler ? This would essentially create a straight thru muffler right ? Very interesting idea.... Might be something to play with this winter
Toque
So if I am reading the thread correctly,it is a piece of tubing that is inserted into the left side of the muffler in this diagram which blocks off the passage where all the red arrows are?
Old Nov 29, 2007 | 06:52 PM
Toque's Avatar
Toque
From: Wylie TX --> Less is More, except under the hood !
I believe you are correct. At least thats the way I understand it. Im working with "johnnied" right now trying to get the information together. I want to go to a muffler shop and have a set made up and detail the install (with pics) for everyone to see.
Toque
Old Nov 29, 2007 | 07:11 PM
uracowman's Avatar
uracowman
Toque
I am thinking about doing this maybe on my magnaflow setup because it is a bit quite for my taste.I hope the interior muffler design is similar....
Old Nov 30, 2007 | 10:30 AM
AMRAAM's Avatar
AMRAAM
I'm almost positive I did not have those. I wonder if I have an older system or something. Without the slots, i am sure the inserts would do nothing but restrict flow. Thanks for the info
Old Nov 30, 2007 | 11:49 AM
Toque's Avatar
Toque
Guys:
I was just told by Corsa, that adding these "inserts" will reduce the exhaust flow a bit. With my car being modified as it is, and dyno tuned to a specific Air Flow Ratio (AFR), I am choosing not to do this mod. If your car is not modified much this might be an idea to make the Touring a bit louder though
Toque
