coras
Old Nov 22, 2007 | 09:39 AM
johnnied's Avatar
johnnied
Default coras
I have the corsa touring, was not happy with the sound to quiet, gave then a call and the send me two insert to make the system sound like the pace car exhaust FREE. I thought that was great
Old Nov 22, 2007 | 10:12 AM
AMRAAM's Avatar
AMRAAM
Hmmmm...Very interesting. I am going to have to look into that. I did a search a while ago to see if it was possible to convert touring to pace car and didn't find anything. Thanks
Old Nov 22, 2007 | 10:34 AM
04 commemorative's Avatar
04 commemorative
St. Jude Donor '17
What do they look like and how do you install?
Old Nov 22, 2007 | 10:56 AM
AMRAAM's Avatar
AMRAAM
Those were my next questions as well
Old Nov 22, 2007 | 12:30 PM
Toque's Avatar
Toque
From: Wylie TX --> Less is More, except under the hood !
What do these inserts look like ? How to install/remove ?
Toque
Old Nov 22, 2007 | 12:58 PM
veni vidi vert's Avatar
veni vidi vert
Old Nov 22, 2007 | 06:28 PM
johnnied's Avatar
johnnied
I meet the rep. at super chevy, we got to talking (that was in the spring) he was talking about taking the mufflers off and sending them in, so I thought I'd wait til the car was not going to be use, called them and he sent them to me. They just are a piece of exhaust pipe around 1 3/4" long and 2 1/4 id and they go in the inlet side and block off that passage to make them louder. He said you didn't have to tack weld but it would be better and just one little tack would do it. That way if you din't like the sound you could remove them
Old Nov 22, 2007 | 08:39 PM
Toque's Avatar
Toque
So its just a small round piece of exhaust tubing that will essentially close off the passages to the "reflective sound cancellation" area of the muffler ? This would essentially create a straight thru muffler right ? Very interesting idea.... Might be something to play with this winter
Toque
Old Nov 23, 2007 | 08:13 PM
johnnied's Avatar
johnnied
they had a muffler cut into their were to passages, he told me two passages touring, one pace car sound. looks like only one in picture?
Old Nov 24, 2007 | 11:02 AM
American Hydrocarbon
Guest
Posts: n/a
Interesting?
Old Nov 24, 2007 | 11:04 AM
lucky131969's Avatar
lucky131969
Love my Corsa Pace Car catback!
Old Nov 24, 2007 | 12:39 PM
Toque's Avatar
Toque
Can you measure the pieces that Corsa gave you to make sure your measurements are correct ? I want to get a set made up to try.
How far into the inlet side of the exhaust is the "passage" that needs to be blocked off. Do you know which of the 2 "passages" needs to be covered up to make the exhaust Pace Car ?
This will prob make my car way too loud (intake/heads/cam/headers etc...). But it will be fun to play around with My Touring already wakes up my neighbors every time I start it up....
Thanks !
Old Nov 24, 2007 | 01:39 PM
Got uid0's Avatar
Got uid0
St. Jude Donor '17
Originally Posted by Toque
C mewasurements
someone is trying to create a new dictionary
Old Nov 24, 2007 | 02:14 PM
Toque's Avatar
Toque
Woops... Fat Fingers again....
Old Nov 24, 2007 | 05:27 PM
johnnied's Avatar
johnnied
I'll try to scan the pictures they send me for direction, the lenth is 1 3/4 and the od is 2 1/4".
Old Nov 24, 2007 | 10:31 PM
Toque's Avatar
Toque
Thanks ! That would be fantastic !
Email: msilverz06@yahoo.com
Toque
Old Nov 25, 2007 | 04:50 PM
johnnied's Avatar
johnnied
I just installed them today only took 45 mintues or so, would have been a little faster if I didn't forget the clamp on the first one. They slide right down and stop on the pipe inside the muffler, they close off the inlet passage. A little louder at idle,didn't drive the car yet.
To coras
Old Nov 25, 2007 | 11:47 PM
Toque's Avatar
Toque
Can't want to hear more of the details, and your thoughts on the change ! Congrats ! I look forward to trying this out as a winter project. If I don't like it then its easy enough to remove !
Toque
Old Nov 28, 2007 | 07:35 PM
Toque's Avatar
Toque
Sent you a PM...
Toque
Old Nov 29, 2007 | 11:17 AM
AMRAAM's Avatar
AMRAAM
I supposedly bought a touring system. i was told to look down the inlet tube and look for openings in the tube. If there were no openings, then it was pace car. I don't see any openings in mine, yet I still think it is a touring system. can one of you guys take a quick pic of the inlet tube? I know it probably wouldn't be easy to get a geat pic, but i would love to see what a touring sytem is supposed to look like.
