AC vacuum line repair
The AC/heater controls in the 99 were not changing the air flow out the vents and after reading other posts, looked under the battery to find the vacuum line was broken and very brittle. It was obvious that the previous owner's battery had leaked and had not been cleaned up, just the battery replaced.
Anyway, I am now in need of advice on replacing/repairing this vacuum line. It is broken about 1 inch after it comes out of the loom and the line going to the bottom seems quite brittle.
What next? Thanks in advance.
Just tape wrap the new line to the wiring harnesses.
BC
Marc
Cant get very good access to the vacuum canister
There wasn't much left under the canister, the line comes out the bottom, takes a 90degree bend and from there all is gone.
I found a couple peices floating around in that area
I can not find the line coming from the back of the manifold. Where does it enter this area? There is a line that is coming out of a loom for about an inch before it broke off. It is marked with the red tape in this pic:
Is that the line going to the inside of the car? I assume so.
So quick summary of my questions:
Where might I find the remnants of the line coming from the back of the engine?
I agree that taking of the fender is a must to get everything cleaned up, I see the fasters on the top, bottom and rear of the fender, but what else needs to be done to remove the fender?
Any other advice.....it is much appreciated.
BTW There are several good threads with pictures in this forum if you do a forum search. I used battery leak
http://forums.corvetteforum.com/show...t=battery+leak
Looks like the next couple days holds some cleaning and reinstallation of parts, and getting the fender back on.
Thanks for all your help on this issue!!!
