washer fluid pump won't stop running
Old Nov 22, 2007 | 07:09 PM
silvervette02's Avatar
silvervette02
Default washer fluid pump won't stop running
I got in my car the other day and the "low washer fluid" light was on. Didn't think much of it but then a couple days later I started up the car and I heard the washer fluid pump running and it wouldn't shut off. Thought it might be a relay but couldn't find one. When I tapped (not push) on the washer button on the multi-function switch it would temporairly stop, then start back up. I think the switch is bad. I ended up having to pull the fuse for the pump/wipers so now I don't have any wipers. I think I am going to have to replace the entire multi-function assy. Anyone have this happen before?
