Random Stalling
Old Nov 23, 2007 | 10:47 AM
vanso06's Avatar
vanso06
4th Gear
Default Random Stalling
Hello all...I have a 98C5 that has stalled twice. Once it stalled pulling up to a red light and the other was a rolling and go after the light turned green. I am receiving no indicator lights or warnings...the car just shuts off. It fires up on first crank and resume normal operation. Confused on what could be causing this...any suggestions would be appreciated. Thanks!
Old Nov 23, 2007 | 11:45 AM
87SAM's Avatar
87SAM
I guess the first thing to ask, have you checked for DIC codes?
https://www.corvetteforum.com/techti...D=25&TopicID=1
Old Nov 23, 2007 | 12:02 PM
timemender's Avatar
timemender
Pull codes as recommended.
May or may not help - My lady friend’s 98 Grand Prix was doing the exact same thing as you describe – (I mean exactly as you described). Had to replace the MAF. Cleaning it did no good.
Old Nov 23, 2007 | 12:24 PM
clownmagician's Avatar
clownmagician
Default Hope you get an answer
I was just going to post the problem and saw you already did it.
Old Nov 23, 2007 | 01:45 PM
TUF-NUF's Avatar
TUF-NUF
From: kent ct - "if i'm not in the vette, i damn well better be on the yacht."
St. Jude Donor '13
Default Check Batt
I had the same problem with stalling out just momentarily and found the terminal on the battery to be SLIGHTLY loose. Could be your problem, and its a cheap check/fix. Dave
Old Nov 23, 2007 | 02:04 PM
stanger383's Avatar
stanger383
St. Jude Donor '09
check the main block ground on the drivers side. Its below the exhaust(kinda a beeoch to get to with headers). Mine had an intermittent stalling problem for a year and a half. thanks to the gus here I finally found it. Hope this helps
Old Nov 23, 2007 | 03:36 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
vanso06
Man,,,thats a tough one. Could be one of 20 things causing it.
Here are some things that I recommend:
Check the wiring harness on top of the engine. The place at the back of the engine where it bends around a black metal bracket can chafe the wires and short out.
Check the door wiring harnesses on BOTH doors. There is a connector that will have a bare wire. The wire is the serial data wire for the doors. If it shorts, some strange things like that will happen.
Just pop out the rubber accordion tube from the door and door frame fish out the connectors from the cavity in the door frame and examine the connectors:
I use liquid electrical tape to cover the wire!
Clean all the grounds.
Check out this post for ground info:
http://forums.corvetteforum.com/showthread.php?t=896875
Clean and tighten your battery terminals, They need to be tightened to 11 ft/lbs.
Hope this helps.
BC
Old Nov 23, 2007 | 07:53 PM
Jeff Jeff's Avatar
Jeff Jeff
I had my '98 stall on me twice. I replaced the fuel filter and have not had another incident in over 2 years.
Old Nov 28, 2007 | 11:01 AM
vanso06's Avatar
vanso06
4th Gear
Default Thank You
Thanks for all the help and advice. I will definitely check the battery terminals as I had it replaced the day before the stall.
To Random Stalling
