**HELP** Oil Pressure Sending Unit
Old Nov 23, 2007 | 12:23 PM
Ta-taaa's Avatar
Ta-taaa
Default **HELP** Oil Pressure Sending Unit
Ok I have made at least three posts on this. I am on, oil pressure sending unit #3. All units read around 100 psi without the car running.
Connections are clean and dry. What are the odds of thee Sending units being bad?
Any ideas out there what else it could be???
Old Nov 23, 2007 | 12:57 PM
50th year's Avatar
50th year
2017 C7 of Year Finalist
I have heard you have to tighten them just right or you will have a problem.
Ron
Old Nov 23, 2007 | 01:05 PM
dougbfresh's Avatar
dougbfresh
Maybe you should read the relocate sticky at the top!
Old Nov 23, 2007 | 02:23 PM
Oldvetter's Avatar
Oldvetter
15 ft-lbs torque and make sure the connector is clean of all oil. Some say the NAPA replacement part works better.
Good Luck, you are due for some.
Do they read any oil pressure with the ignition on and the engine off? If they do the sensor is bad. If no pressure reading, your sensor is okay, look elsewhere for problem.
Old Nov 23, 2007 | 04:34 PM
Ta-taaa's Avatar
Ta-taaa
They all read around 100psi with the ignition on. I even took the last one and just grounded it out on the block and connected the wires. No way I got that one to tight..
Old Nov 23, 2007 | 05:59 PM
RichieRichZ06's Avatar
RichieRichZ06
From: Supporting the Corvette Community at Abel Chevrolet in Rio Vista, CA 707-374-6317 Ext.123
St. Jude Donor '08
If it is a GM part, it carries a 12/12 warranty. The dealer should give you a new one for free if you purchased it there.
Old Nov 23, 2007 | 06:03 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
By all means, if you bought it from GM, return it so they start getting a record of these failures. I relocated mine and have zero problems since.
To **HELP** Oil Pressure Sending Unit
