FAST 90/90 Set Up
Old Nov 23, 2007 | 08:23 PM
js23881's Avatar
js23881
Default FAST 90/90 Set Up
Looking for opinions...
First my current mods on a built A4 99 coup.
  • 402 forged and stroked engine.
  • LS6 intake, 78 mm TB
  • 60 lb Moltron injectors
  • 98 Fuel rail system with KB Boost Pump, LPE Fuel pump
  • Alky Injection
  • Z06 3:42 rear hard driver side shaft
  • Procharger D1, 8 rib system, 13 lbs boost
  • 3000 stall, Protorque convertor
  • Blower cam
  • 611 RWHP and 600 RWT on 90 degree day.
  • Run consistant 10.05-10.16 in 1/4 mile.
[/list]What I'm looking for is a little extra torque to get me under 10 seconds in the 1/4. I 'm thinking a FAST 90/90 set up should be my next move. I would think the current small 78 mmTB is my weak area in my set up. Anybody agree...or disagree??
I also have some surging at idle that could probably be fixed if I drill a small hole in my 78 mm TB throttle plate but not really wanting to do that. I think a larger 90 mm TB would also address that....Agree or disagree??
Please advise your thoughts on all this if you can...would really appreciate any input...Thanks-
Old Nov 23, 2007 | 08:42 PM
Tony Mamo @ AFR's Avatar
0Tony Mamo @ AFR
Former Vendor
Get one and have it ported to maximize your return....
It's probably worth 15-25 RWHP (peak) depending on cylinder heads, exhaust, and the rest of the combination. It will also carry better past peak (power will hang on a bit longer) which will allow you to shift a few hundred RPM higher which will help the next gear start a little higher up in the RPM band so your average power thru the run will be up noticably.
It should get you the tenth and a half or so your looking for....
What heads are on this engine btw?
Tony
PS....The SOTP and throttle response will also noticably improve.....a nice fringe benefit of the swap.
Old Nov 23, 2007 | 08:56 PM
js23881's Avatar
js23881
Default Heads
Tony-
Thanks for reply....using Patriot Stage 3 heads. Have 9.3-1 CR.
What does SOTP stand for
Old Nov 23, 2007 | 09:02 PM
GKE's Avatar
GKE
Seat Of The Pants
Old Nov 24, 2007 | 10:35 AM
Jeffs FRC's Avatar
Jeffs FRC
I gained 20rwhp and 10rwtq with a FAST swap from a LS6/shaner tb setup. My FAST was home ported by me and the LS2 tb was ported by Speed inc.
To FAST 90/90 Set Up
