Car boggs off the tree BAD!
The Car boggs off the line very very bad. The second half of the quarter it pulls like a freight train. but out of the hole it feels like I am towing a freight train!
On previous trips to the track I experienced tire spin and eventually the car would hook and go, today, I could barely do a burnout. (I have line lock so A burn out was possible) but just nailing the throttle there was nothing. Yes I did have the traction controll off, I tried in competitive mode and with out comp mode, no difference. The oil pres was good the temp was good, all the guages were right where they were supposed to be. The car seems to drive OK and acceleration from about 35 MPH seems to be unaffected.
I need help! I'd hate to have to go to the dealer. I wrench on all my cars myself, and now I have no idea where to look.
And that was on that crappy fbody 10 bolt, in an M6. :X!
Good luck and keep us up to date on your find.
-X-
Thanks, keep throwing ideas out. You never know when the right one will come up.
1. You have a really really sticky tire that is hooking up nicely and causing you to feel like your bogging. (Check tire pressures and try adjusting to remove some of the squishiness in the tire) Low pressures obviously will hook you up better and cause less wheel spin but will also absorb a lot of your energy (causing somewhat a bogging feeling)
2. Just not enough power, you need more power if your going to stay with these new slicks you got. To roast them up the way you want, either your going to have to get a better torque converter, change the gearing to lower it, go 4:10's if draging the 1/4, or do something to the motor to generate more power. Or if you have the cash do all of these.
I would think that fooling with the tire pressures might help dial in the new slicks better, but feel your not probably going to get the results your looking for. But hey its free.
Going to a new torque converter will definitely help your launch and roasting the tires. I think this is your weak spot now. Sounds like you went to a new super sticky slick and your stock stall converter just aint cutting it anymore. Once you do get a new stall converter, adjust the shift points and hardness through either a programmer or a tuner, that too will help a lot.
The gears, I forget if you mentioned what your auto had, if its the 2:59's then there is no wonder why your bogging, but even if you have something in the 3:s range, a set of 4:10's for what your doing I have heard will make you feel like you have 100 extra HP.
Good Luck
-X-
Good Luck
-X-
Seems like your tires may be a bit too soft and your converter is too weak. Put more air in the tires to help dial them in better, and get a steeper stall converter. One more thing, how much power is your car making without the nitros? Maybe the slicks are killing your launch because your not making enough power down low to get them going without bogging too much. If you have a relatively stock engine, making minimal power, slicks will hurt you more than they help you.
Oh well, I might run like crap, but i looked good doing it
[IMG]
[/IMG][IMG]
[/IMG]
1. where can I buy gears/rear used for the best price?
2. What spec converter should I look for? I still want to street drive the car regularly so i dont want to sloppy of a converter, and the motor is basically stock (bolt ons) and bottle.
3. how to check spark timing retard?
I didn't even consider that as an option. The car seemed to drive fine. I could not hear any spark knock. Of course with the helmet on and loud exhaust in the next lane, it would be tough anyhow.
A popular drag racing/street gear is 3:42's. with a 3600 stall convertor.
ECS has gears & can also install same day.
Did we ever meet at Cecil ?
Jay
I take it you have not had hardend outputs shafts installed in your differential. If not, eventually, you will not drive your car home from the strip.
If you're following conventional wisdom on hitting the spray, think back and see if there is anything else that changed or you are doing different.
And back up the thread was what I think was a suggestion to bring up rpm's in neutral and slam tranny into first gear. Two things argue against that.
1. Unless it has changed, NHRA rules (maybe all the sanctioning bodies) don't allow this, because
2. It's a good way to grenade the converter/tranny and dump lots of transmission fluid on the track.
On the other hand, it may be a way to get that high stall converter 'cuz neutral starts are going to eventually break something.
Charlie
Before the slicks, I was launching without the bottle, and flipping the arming swithch as I passed the tree. I am using a WOT (wide open throttle switch) so with the system armed when I hit WOT the nitrous sprays (with the fuel).
This weekend, when I launched, because i was using the slicks, I launched with the nitrous armed. So when the pedal hit the floor I was all in. I honestly expected to launch hard because without the slicks it spun. now adding the bottle I thought that would compensate for the slicks.
Like I said earlier, it pulls hard at the top, just not out of the hole.
Thanks again for all the suggestions
