Well I just purchased my first vette. After years of dreaming. 99 with about 73k on it. Overall it's in good condition but has a few issues I could use some help with.
When braking, at low speeds 15mph or so I get a vibration. It's not in the pedal. No vibration at any other time. It's not really a vibration exactly, but more like the brakes are catching and releasing, not fast like abs but much more spaced out...even causing the car to almost surge (also similar to a separated tire but it's only on braking slow speeds). If I get hard on the brakes in a quick stop, I don't notice it. If I heat the brakes up, it seems to settle it a bit for a while. Now, my first instinct is the rotors are warped. But usually you would feel this in the pedal. Which I don't...I have never owned a car with rear disc brakes before so I am not sure the impact of warped rotors on the rear. I have also noted the parking brake does not hold. I don't know if that is a correlation or not. If anyone has any tips or been there done that, I would appreciate your input.
Perhaps changing the pad material would help, but I wanted a solution that did NOT require
a) Bedding the brakes to an exact 5-step procedure
b) Limiting my brake pad selection to only certain types
I had the same issue with my vette when I got it. I had the brake rotors resurfaced, and it took care of the problem temporarily. It is back again, after a year, so I am switching to drilled and slotted rotors.I don't track the car so it isn't a question for me about the rotors. I'm also trying GM ceramic pads I'm getting from Gene at GM Parts. Just waiting for the pads to come in so I can make the complete changeover.
The answer though, is pad material on your rotors. There are lots of posts on rotors, so you might want to do a search to get some more info on this to make a choice if you want to get slotted, drilled and slotted, dimpled, or just plain NAPA ones for about $25. Good luck.
try the hard braking as spoke of earlier. it does work most of the time. do not come to a complete stop till the brakes have time to cool after the procedures though. mine did this occasionaly with drilled and slotted rotors and ceramic pads. people tend to stomp on the brakes in these cars a little more than a normal sedan so the brakes tend to get more of this uneven pad transfer on them from the heat and pressure generated.
Just an observation; I've had several cars that had warped rotors, and I never had one that made the pedal pulsate. You could feel it in the wheel, or the car body, but never in the brake pedal. New rotors always fixed it.
Good post up Dave. I agree with you as to the causation of low speed pedal pulsation on most vehicles. The vast majority of the times, this symptom is NOT due to warped rotors.
Thanks, Lonestar,
I really like every other characteristic of the GM pads - just not the adhesion of material to flat rotors. The slots in my PowerSlot rotors not only keep the pulsations away, but they also keep the pads fresh, especially when it comes to low-mileage cars that often allow glazing of the pads to form.
I had a interesting problem with brake pulsation on my 04 Z06. I put on a set of drilled and slotted rotors and shortly there after I picked up a vibration on slow speed braking just before coming to a complete stop. I lived with it for a while thinking that I did not seat them properly or that they were warped. Well I finally got pi**** and bought a new set. When we were replacing them we ran into a problem on removing the drivers rear rotor it would NOT come off! Well we finally got it off and found the emergency brake shoes had come off their mounts!! Long story short we reassembled them put on new rotors and no vibration. A friend in the club bought the first set and installed and has no vibration at all with the first set. So before replacing or turning your rotors check your emergency brake shoes on BOTH sides.
Originally Posted by Dave68
Thanks, Lonestar,
Dave
That's why I went with cheese graters too. Baer Eradispeed+1s with slots only. No holes.
