Fuel pump ?
Old Nov 21, 2001 | 07:07 PM
Skeeter1's Avatar
Skeeter1
Default Fuel pump ?
now im a little confused.i thought the walbro 340 was an inline addition to the stock pump, but Im learning its intank, does it replace the stocker or work concurrently with it, or what ? Its application is on a c-5 422 which with 42 lb injectors should be ok on moter, then a TNT wet kit on top of that starting with the 100 jets and eventually going to 250. any suggestions ?
Old Nov 21, 2001 | 08:55 PM
STEALTH C-5's Avatar
STEALTH C-5
Default Re: Fuel pump ? (Skeeter1)
Skeeter,Your stock fuel pump should be fine for your set up on motor only,it's supposedly good to 525 rwhp,if your going to spray anything on top of that you need an independent fuel system for the nitrous.
Old Nov 21, 2001 | 11:09 PM
Skeeter1's Avatar
Skeeter1
Default Re: Fuel pump ? (STEALTH C-5)
Mike, when you say independant fuel system what is involved ? is it as simple as adding an inline pump to allow for increased pressure when spraying, or what.
Old Nov 22, 2001 | 11:52 AM
STEALTH C-5
Skeeter,Cartek will be installing an independent fuel system on my car in the spring,I don't know exactly what it will consist of but it will need to handle 650+RWHP with the spray.I would call Jung Performance in Ft.Lauderdale,they have quite a bit of nitrous experience and see what they say,whoever does it they better know what they're doing or you'll lose that motor.I'm lucky to have Julio from Cartek rigging my car as I've been to Pat Musi's shop and seen Julio set up 1000 HP nitrous systems.I wouldn't let anyone else touch my car with nitrous.
Old Dec 2, 2001 | 01:19 PM
Austrian Vette's Avatar
Austrian Vette
So where to get a fuel system for strocker + NOS??
I cannot come to USA to have it installed :cry :cry :cry
Michael
Old Dec 2, 2001 | 01:26 PM
Paradigm's Avatar
Paradigm
Default Re: Fuel pump ? (Austrian Vette)
there are a bunch of aftermarket pump suppliers but mainly, they have knowledge/experience building FP's for carbureted cars. This essentially leaves the market open for a high pressure/high volume in-tank unit that is rated for constant duty cycle.
Anybody that has specs on the currently available, high performance pumps, please post them.
Old Dec 2, 2001 | 01:28 PM
Godspeed's Avatar
Godspeed
Senior Member
Cruise-In III Veteran
Cruise-In IV Veteran
Forget the seperate fuel system stuff and install an ARE dual Walbro in-tank pump setup.
Old Dec 2, 2001 | 01:34 PM
Austrian Vette
Default Re: Fuel pump ? (Godspeed)
But will that setp be good for a 500rwhp engine + 300rwhp NOS??????
Maybe MattG or Nick can help me out!!!
Don´t want to run out of fuel on my heads/cam + 150 wetshot.
And if I upgrade my fuelsystem, then it should be good enough for my
next project that I plan next winter. 800rwhp is a must, then!!
Michael
Old Dec 2, 2001 | 02:16 PM
Tom Hall's Avatar
Tom Hall
Nick told me a little bit on the 422 set up with direct port Nitrous. Their will be a dual pump in the tank and a separate system for the N20. It will have its own fuel cell and pump. You will run high octane fuel in this tank. I don't know how big the fuel cell is. I think it will go in one the rear storage compartments. I need to get the Engine in and running and then I will work on the fuel system.
I just want to drive my car around the block again :cry
Old Dec 2, 2001 | 02:22 PM
Austrian Vette
Default Re: Fuel pump ? (Tom Hall)
Tom,
Hope to get info´s about that dual fuel pump!!
(Maybe MAttG sees the post :))
Seems to be enough for me with heads/cam and 150 NOS!
And later I may have to do an extra fuel cell also.
I can look how your´s works :D
Keep me updated on your engine and furlsetup!!!
Thanks,
Michael
To Fuel pump ?
