Tire type?
Old Nov 27, 2007 | 06:37 PM
firebal's Avatar
firebal
8th Gear
Default Tire type?
I have just purchased a 2000 C5. The tires need to be replaced.
When driving the car it follows the ridges on the street quite badly.
I am unsure if the tires on the car are RUN FLAT. will it be better if I purchased regular type tires? or do they both do that?
Thanks Richard
Old Nov 27, 2007 | 06:48 PM
87SAM's Avatar
87SAM
Unless you have very wide tires on the front, it sounds more like an alignment issue.
Old Nov 27, 2007 | 08:43 PM
firebal's Avatar
firebal
8th Gear
Default Tire type
The car drives straight as a die on good roads, no pulling at all.
I only notice it when I go over rough scored roads.
I was hoping it was becaurse the tires I have on are Run flat with very stiff sidewall.
To Tire type?
