anyone see the trickflow package at summit racing?
I thought I read that they changed the geometry on the TF heads, and they no longer need aftermarket RRs. I know my early set have the 7.9" PRs and DO require RR, but thought they'd changed the design slightly? The current ones are supposed to use a 7.5" PR, too.
BTW, I didn't have any fitment problems with the HS rockers and my stock center bolt valve covers.
AWESOME! Did you do anything to the running gear or clutch? I am looking at this setup for my soon to be 97 MN6 Coupe....it has 40K miles and is all stock (including the clutch) I wonder how long that would last....I don't plan to drag the car- just make a mean street machine for a daily driver!
Not first owner, so I don't know for sure on clutch. I beleive it is original. Looking to update rear to a 4.1 over this winter. pm me if you have any questions.
here is one of our customers cars with Trick Flow Heads and Our Custome Cam Dyno with over 500rwhp
http://www.ecsracing.com/ecsracing/showthread.php?t=27
Bob,
Was that car ever run in the quarter, and if so, what was the mph?
Thnaks, Rich
St. Jude Donor '05-'08
The car was run at Atco 2 weeks ago. Mike69 was not runing well and Doug said I will give you one more shot then I am going to run your car. Mike proceeded to run 10.9. Doug took 1 run and matched his time
Mike ran 10.9x @ 126 mph
I stand corrected, I was going by the Summit web site info. I don't want to be the guy who posts false info on here. So I called summit because their on line adds say that rockers are not included. They told me that the rockers are included with the three different kits. When you factor in the rockers it looks like a good deal.
