Adjustable end link question
Old Nov 28, 2007 | 09:15 PM
97C5driver's Avatar
97C5driver
Default Adjustable end link question
I just recieved a set of adjustable metal end links from a great member here by the name of Randy814u.
Well I was wondering which way the adjustable side of the end link mounts. To the control arm or to the sway bar?
Also, any idea what they should be adjusted to for a z06 sway bar?
thanks.
Old Nov 28, 2007 | 11:04 PM
97C5driver's Avatar
97C5driver
also, do i need 2 spacers per side of the end link? They are the ecklers kind and show only 1 spacer per end. I was browsing through some threads and found pics of a T1 bar with adjustable end links and they had 2 spacers per end.
I cant wait to get these links and this bar hooked up. I just want to make sure i don't install it wrong.
this is the photo of a T1 with adjustable end links I found here on the forum, Im going to be using the z06 bar, should it look like this anyway with the 2 spacers on top and bottom
Old Nov 28, 2007 | 11:16 PM
Higgs Boson's Avatar
Higgs Boson
First, why did you buy them? What do you intend to gain with adjustability?
Old Nov 28, 2007 | 11:33 PM
97C5driver's Avatar
97C5driver
Well I was looking for stock metal end links but Randy814u hooked me up with them for free! so I figured they would be just as good if not better thna the stock metal links.
Old Nov 29, 2007 | 12:51 PM
97C5driver's Avatar
97C5driver
ttt
To Adjustable end link question
