Heat temperature problem
Old Nov 29, 2007 | 12:44 AM
lazya's Avatar
lazya
Cruising
Default Heat temperature problem
I have a 98 Coupe, when it is cold outside normally you would set the temperature to around 72. When the car is on for a minute or so the temperature on the heat is as if the setting was set to full 90. If you turn it down to 63 then you will get mild air. As the car warms up after 15-20 minutes then you can slowly start to increase the temperature. Also I don't think the ducts are working properly, when I set it to air up to the windows there is still air coming out from the front ducts, don't know if that is normal. Any help or ideas would be appreciated..
