Looking for Brake Pad recomendations
Old Dec 2, 2007 | 03:22 PM
KamiLos's Avatar
KamiLos
hawk street pads up front and reysbestos pads in the rear. i liiiiike
Old Dec 14, 2007 | 01:43 PM
falcon9's Avatar
falcon9
OK so I installed the Raybestos Quiet Stops and I like them.
My only question now is how you guys deal with the restricted space of the wheel wells? I found breaking loose those 19mm molts with loc-tite nearly impossible. There was just no space to swing a breaker bar. On the front I could at least turn the wheels out to get more working space but the rear was a nightmare. Same goes for the torque wrench to finish the job.
By the way I was using the new Sears "Lift and Secure" jack. I must say I think it is a great idea. It is a little too tall so I drove the car onto 2 pads made up of 3 pieces each of 3/4" scrap plywood about 12" square. Then there was plenty of clearance for the jacks. I like it because I just put it under the lift points, lift the car then leave the jack stand portion behind. It comes with 2 jack stand attachments. I bought it because I needed to remove my steering column to replace the position sensor a few weeks ago and I got frustrated lifting it with my old jack and trying to figure out where to place the jack stands.
Any way thanks for the suggestions.
Mike
Old Dec 14, 2007 | 02:11 PM
C5Natie's Avatar
C5Natie
Performance Brake Systems z-rated pads for me. Theyre carbon metallic and bonded. Their pads are actually patented. Z-rated front pads can be over $200 but kragen and autozone have them for $108-150 2yr to lifetime warranty.
