Noticeable fuel pump whine normal?
Old May 20, 2008 | 11:36 AM
romeokc10's Avatar
romeokc10
Originally Posted by indieaz
Mine is extremely loud as well. When i turn on turn signals the whine changes pitch with the signal blinking. It's annoying. It seems to have gotten noisier lately though, I know I need to replace my fuel filter though and am doing that tomorrow.
A new thing today, when i turn the key to the on position and the pump turns on to prime the fuel system, i'm hearing a sloshing noise (sounds like gas is sloshing around in the tank). Never noticed it before...hope the pump isn't dying.
My 99 Coupe is not loud but it is annoying when I notice it, and like yours the pitch changes when using the turn signals. It also seems like I can hear the sound coming from the stereo speakers, I guess I'll change the fuel filter and start there.
Old May 20, 2008 | 10:41 PM
GrayC5's Avatar
GrayC5
Originally Posted by Bluefire
My cars birthday is March 17, 2003. Does this mean I got lucky and the fuel filter is on the outside of the fuel tank?
No.
Partway through model year 2003 (beginning with 2003 VIN 35114929 produced on 11/25/02 so I've read), GM introduced the newly redesigned FFS fuel system on the C5. Later model year 2003 and all 2004 C5s have the redesigned FFS fuel system which was carried over to the C6. With this new design, the fuel filter was moved inside the left fuel tank and is part of the left fuel sender assembly. The left fuel sender assembly also includes a fuel level sensor, the fuel pump and reservoir assembly, the fuel pump strainer and the primary fuel pressure regulator. The left fuel sender assembly is replaced as a complete unit and the tank has to be dropped to replace the sender unit assembly.
The following link contains more info on the redesigned FFS fuel system:
2003 - 2004: Service Information: Fuel Tank System
Old Jun 16, 2008 | 11:47 AM
rraulston's Avatar
rraulston
so where is the fuel filter on early 2003's located at????
Old Jun 16, 2008 | 01:23 PM
LoneStarFRC's Avatar
LoneStarFRC
I don't know what the break point was in '03, but one way to find is to get it up in the air and look to see if the filter is mounted on the inside of the L/R frame rail.
HTH
Old Jun 16, 2008 | 01:24 PM
Bill Dearborn's Avatar
Bill Dearborn
On the drivers side frame rail like all previous C5s.
Bill
Old Jun 17, 2008 | 03:04 AM
PierEagle's Avatar
PierEagle
Originally Posted by Fast one
A dirty fuel filter can cause the pump to work harder and result in more noise, I changed one after 50,000 miles and it was partially plugged.
I could hear mine whining. Had the fuel filter changed last week. Whining sound has all but disappeared...or my hearing could be getting worse.
