Noticeable fuel pump whine normal?
Old Nov 30, 2007 | 08:10 PM
Bob Landdeck's Avatar
Bob Landdeck
Default Noticeable fuel pump whine normal?
I have a noticable whine from under the drivers seat, I assume it is the fuel pump. I recall that the fuel pump on my 2000 Chevy truck got noisy before it died. Is some noise at idle normal? The gas guage is at 2/3 full now but the noise seems pretty consistent. The sound changes pitch when a turn signal blinks or when I turn on anything electrical.
Old Nov 30, 2007 | 09:02 PM
HP_Addict's Avatar
HP_Addict
The fuel pump is located in the driver rear wheel well, so kinda behind teh driver. They can whine sometime, normally when they get real hot. If your is changing pitch with the blinkers, you might have something else wrong. Try to determine if it definitely the fuel pump. Start the car and listen around the wheel well for the sound.
Old Nov 30, 2007 | 09:04 PM
Bill Dearborn's Avatar
Bill Dearborn
The fuel pumps on the early C5s 97 through 98 were very noisy. GM redesigned the fuel pump for the 99 cars so they made less noise. GM would replace the pump under warranty for the older cars if the owner complained.
Bill
Old Nov 30, 2007 | 09:09 PM
Wayne's World's Avatar
Wayne's World
It is normal for the fuel pump in early C5 Vettes to be loud.
I hear it over my left shloulder, the pump is in the left rear behind the driver.
Later models have a more quiet pump installed.
I have read many a post about it.
After I start driving and I get to grinning I don't hear it any more.
Old Nov 30, 2007 | 09:12 PM
slowtealz28's Avatar
slowtealz28
I've got the same exact problem and I've been wondering about this as well.
Old Nov 30, 2007 | 09:18 PM
Oldvetter's Avatar
Oldvetter
Bob, you should fill out your profile, so we know what year car and where you live.
The early year (1997 and 1998) had some noisey fuel pumps that could have been replaced under warrenty. They are not bad, just noisey.
My 1998 makes some whine when it is cold, but it goes away as the car warms up. It is never noisey in the summer.
The 1997 and 1998 are cheap to change the fuel filter, cheap insurance that a clogged fuel filter is not the problem..
Old Nov 30, 2007 | 09:23 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
What year car do you have? The pump is inside the tank and on 97 & 98 C5, they were noiser than the later ones. I had the one in my 98 replaced with a 99 pump under warranty cause of excessive noise
Old Nov 30, 2007 | 09:40 PM
2blklt4's Avatar
2blklt4
same thing here...NORMAL
Old Dec 1, 2007 | 09:49 PM
jim dodd's Avatar
jim dodd
my pump does the same thing and the turn signals also done it since i brought the car 3 years ago no prodlems yet 98 vet 100 000 miles this week .
Old Dec 1, 2007 | 09:59 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
98s were noisy. HAD my 98s pump changed out under warrenty and,,,,,,,,,,,,,,,,,no more NOISE issues!!!!!!!!!!!!!!!!
Old Dec 1, 2007 | 10:10 PM
waterzap's Avatar
waterzap
I like the noisy pump. One more thing I dont have to worry about. If I hear it, it is working fine :-)
Old Dec 1, 2007 | 10:17 PM
Dirty Howie's Avatar
Dirty Howie
Mine was replaced under warrantee when I complained about the whining sound.
DH
Old Feb 2, 2008 | 10:19 AM
eddy20's Avatar
eddy20
Default noise
ttt, I feel better now, thanks again to the form!
Old Feb 2, 2008 | 11:33 AM
Fast one's Avatar
Fast one
A dirty fuel filter can cause the pump to work harder and result in more noise, I changed one after 50,000 miles and it was partially plugged.
Old Feb 2, 2008 | 11:53 AM
Bluefire's Avatar
Bluefire
My 2003 Coupe has this whine about 1 out of 15 startups. I like the partially clogged fuel filter theory. I think I will look into that.
Old Feb 2, 2008 | 05:04 PM
Dirty Howie
You may find out that the fuel filter is part of the fuel pump system and is inside the fuel tank. It is considered a no servicable item ........ at least it is on my 2004.
DH
Old Feb 2, 2008 | 05:39 PM
JH's Avatar
JH
If your car is a mid-model-year 2003, or a later C5, the fuel filter will be INSIDE the gas tank.The EPA required a running change in mid-2003 that put the fuel filter in the tank, and downgraded the fuel injection system. The latter is no big deal unless you mod for really big HP, then you will need a new FI system. However, the filter inside the tank was a deal stopper for me when I was shopping.
I looked for a '02 instead, having changed a few fuel filters in more than 40 years of car ownership, dropping and draining the fuel tanks to do so makes no sense to me.
Good luck!
To Noticeable fuel pump whine normal?
Old Feb 2, 2008 | 10:57 PM
im-vettin-on-it's Avatar
im-vettin-on-it
i have a 98 and the fuel pump whine is really loud, I installed ome lt headers and magnaflow exhaust and it made it go away!!!!!!!!!!!!!!!!1
Old Feb 10, 2008 | 07:04 PM
indieaz's Avatar
indieaz
Mine is extremely loud as well. When i turn on turn signals the whine changes pitch with the signal blinking. It's annoying. It seems to have gotten noisier lately though, I know I need to replace my fuel filter though and am doing that tomorrow.
A new thing today, when i turn the key to the on position and the pump turns on to prime the fuel system, i'm hearing a sloshing noise (sounds like gas is sloshing around in the tank). Never noticed it before...hope the pump isn't dying.
Old Feb 11, 2008 | 06:34 PM
Bluefire's Avatar
Bluefire
Good luck!
My cars birthday is March 17, 2003. Does this mean I got lucky and the fuel filter is on the outside of the fuel tank?
