Tires - 270/40-17 front okay
One last time, before I pull the trigger in the next few days. I'm going to Z06 Chrome reproductions in Z06 size. Planning to put on 275/40 - 17 front and 295/35 - 18 rear. Either Michelin Pilot sport or Yokohama AVS.
Looking for any last minute advice on my choices. Specifically, fit on the front (I am not lowered).
Re: Tires - 270/40-17 front okay (jschindler)
Okay, I promise (moderators) this will be my last attempt to get input. I plan to place my order for wheels & tires tomorrow (Friday).
Hey Jim, I think we talked about my setup, which is the 275's on the front with the Yoko's, but my car is lowered. The Yoko's run a little wider than most other tire brands. I love them. :cheers:
Re: Tires - 270/40-17 front okay (C5 YA)
I would get the KD's as the side wall strength in the Michelin's isn't the greatest. Decent tire though for the average ride.
CF Co-Founder
I have 285s on the front. Michelin Sports. Not lowered and no problems. The wheels are CCWs. See sig.
Re: Tires - 270/40-17 front okay (Troy Roberts)
Thanks for all the help. Needless to say, I got different advice- which is normal, so I did not take some of your advice. But really appreciate the responses. Wound up ordering Michelins for a variety of reasons (partly availability).
Troy - you'll be happy to know on the wheels and tires I'm supporting two Forum Vendors. Thanks for your input.
CF Co-Founder
Re: Tires - 270/40-17 front okay (MySea5)
Hey Ken. Getting Z06 Reproductions in Z06 size (From COH), and Michelin Pilot Sports - 275/40 - 17 front and 295/35 - 18 rear. Hope to have them on by next weekend.
Need to sea you some time. You going to Westheimer/Post Oak soon? I'll go if there is a good group. Went to the car show today - JW's car looks good, anxious to hear more about his head/cam pkg.
LS1Edit Guru
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Those sizes should be fine. The fronts will be .02" smaller and 1.18" wider than stock so no big deal. The rears will be .53" smaller and .79" wider than stock so again, no big deal. However, bear in mind that you will be effectively lowering the rear without lowering the front. If you want to keep the aspect (rake) closer to stock, using 265's in front may be a better choice or even better, run 315's in the rear which are identically matched in diameter change from stock as the 275's will be.
[Modified by nevrenuf, 2:01 PM 11/24/2001]
Re: Tires - 270/40-17 front okay (nevrenuf)
There are no 315/35's. In fact, it is my hope that they come out with them as I expect my rear tires to wear faster than my fronts.
Re: Tires - 270/40-17 front okay (COOL COUPE)
John and Cool coupe - thanks for the vote of confidence.
John - saw your car at the show - looking good. Let me know how everything has worked out on your latest "project".
