CodE: C1282 .. Serious ????
Old Dec 2, 2007 | 11:39 PM
Dirty Howie's Avatar
Dirty Howie
Default CodE: C1282 .. Serious ????
Was driving along and thought my engine or tranny locked up. But I guess it was my traction control system. Got DIC warning to service traction control. And got this code. I cleared it and it didn't come back
It is YAW CONTROL BIAS SYSTEM FAILURE
Does anyone know what I should expect??
If it goes out can I just turn TC off or am I gonna get stuck????
DH
Old Dec 3, 2007 | 01:31 AM
Bill Dearborn's Avatar
Bill Dearborn
Any code in the ABS system will automatically turn off the affected portions of the system so you don't have to do anything to turn it off and you will not get stuck. C1282 shuts down the Active Handling and the Traction Control but not the ABS. Here is the description of how this part of the system operates and the actions taken by the car when the code occurs.
DTC C1282
Circuit Description
The vehicle stability enhancement system (VSES) is activated by the electronic brake control mdoule (EBCM) calculating the desired yaw rate and comparing it to the actual yaw rate input. The desired yaw rate is calculated from measured steering wheel position, vehicle speed, and lateral acceleration. The difference between the desired yaw rate and actual yaw rate is the yaw rate error, which is a measurement of oversteer or understeer. If the yaw rate error becomes too large, the EBCM will attempt to correct the vehicle's yaw motion by applying differential braking to the left or right front wheel.
The amount of differential braking applied to the left or right front wheel is based on both the yaw rate error and side slip rate error. The side slip rate error is a function of the lateral acceleration minus the product of the yaw rate and vehicle speed. The yaw rate error and side slip rate error are combined to produce the total delta velocity error. When the delta velocity error becomes too large and the VSES system activates, the drivers steering inputs combined with the differential braking will attempt to bring the delta velocity error toward zero.
The VSES activations generally occur during aggressive driving, in the turns or bumpy roads without much use of the accelerator pedal. When braking during VSES activation, the brake pedal will feel different than the ABS pedal pulsation. The brake pedal pulsates at a higher frequency during VSES activation.
Conditions for Running the DTC
The EBCM performs 6 different tests to detect a DTC condition. The numbers below correspond to the numbers in Conditions for Setting the DTC.
1. The yaw rate sensor bias test runs with the ignition ON.
2. The yaw rate sensor acceleration test runs with the ignition ON.
3. The yaw rate sensor circuit test runs with the vehicle stopped or with the vehicle speed greater than 45 km/h (28 mph).
4. The yaw rate isolation test runs with the following conditions:
-The brake pedal is not pressed.
-The ABS is not active.
-The vehicle speed is greater than 5 km/h (3 mph).
5. The above yaw rate isolation test run with the VSES active.
6. The false activation test runs with the VSES active.
The EBCM performs 6 different tests to detect a DTC condition. The numbers below correspond to the numbers in Conditions for Running the DTC.
1. The yaw rate bias is greater than 7 degrees/second.
2. The yaw rate input change is greater than 390 degrees/second/second.
3. The yaw rate input voltage is less than 0.15 volts or greater than 4.85 volts for 1 second.
4. The yaw rate error is greater than 10 degrees/second 30 times within a drive cycle.
5. The yaw rate error is greater than 10 degrees/second for 5 seconds. Under this condition, this DTC will set along with DTC C1281.
6. The yaw rate error is greater than 10 degrees/second with the vehicle speed less than 60 km/h (37 mph) and the acceleration pedal is pressed more than 25 percent of the pedal travel range for 1 second during the VSES activation. Under this condition, this DTC will set along with DTC C1281.
Action Taken When the DTC Sets
The EBCM disables the VSES for the duration of the ignition cycle.
The Traction Control and Active Handling indicator turns ON.
The DIC displays the Service Active Handling message.
The ABS remains functional.
Bill
Old Dec 3, 2007 | 10:02 AM
Dirty Howie
DTC C1282
Circuit Description
Bill
Thanks Bill
I did do a search after posting and found this info you posted elsewhere.
But thanks for the assurance that I wont get stuck.
So I may get an unwanted braking episode followed by an automatic deactivation of the system. Most worried about an upcoming track event......
DH
Old Dec 5, 2007 | 01:44 AM
Dirty Howie
Defective/Failed Yaw sensor ...... being replaced now.
DH
Old Nov 19, 2020 | 09:04 PM
Fahad Ahmed's Avatar
Fahad Ahmed
1st Gear
Default I have fixed the code c1282 by replacing yaw sensor
See the video:
DH
Old Nov 20, 2020 | 08:23 AM
bjones7131's Avatar
bjones7131
DH
Educate me, what is the YAW sensor and what and where is it? Thanks
Old Nov 20, 2020 | 10:14 AM
oelarse's Avatar
oelarse
A yaw-rate sensor is a gyroscopic device that measures a vehicle's yaw rate, its angular velocity around its vertical axis. The angle between the vehicle's heading and velocity is called its slip angle, which is related to the yaw rate.
The location is shown in the video above , left side of center console
Old Nov 20, 2020 | 10:31 AM
grinder11's Avatar
grinder11
Better to start a new thread-This one was/is 13yrs old!
To CodE: C1282 .. Serious ????
