gring going into 6th
Old Dec 3, 2007 | 07:33 PM
CARRJET's Avatar
CARRJET
Default gring going into 6th
has anyone had a grind going into sixth at High RPM's around 78 MPH when winding her out? all other times when not gettin on it shifts fine.
Old Dec 3, 2007 | 09:52 PM
speedsk899's Avatar
speedsk899
You go into 6th at high rpm's and you are only going 78MPH? Are you shifting from 2nd to 6th?
Old Dec 3, 2007 | 10:07 PM
CARRJET's Avatar
CARRJET
no, 5-6th and RPMs around 5000
Old Dec 3, 2007 | 10:21 PM
speedsk899's Avatar
speedsk899
I must be misunderstanding.........I can do the 78MPH in second gear. How are you at only 78MPH at 500RPM in 5th gear?
Old Dec 3, 2007 | 11:44 PM
emquad46's Avatar
emquad46
3rd gear redlines (6000rpm) @ 105mph with 3:42 rear gears, ,4th redlines @ 140mph(6000rpm) 3:42 rear gears.. Don't know what gear you are throwing @ 78mph to get to 6th ..5th should be turning about 2500rpm @78mph. My shifting from 5 to 6 is effortless at any speed over 60mph.
Are you pushing the clutch to the floor?
Old Dec 3, 2007 | 11:47 PM
z06brah's Avatar
z06brah
rofl
Old Dec 4, 2007 | 08:21 AM
9secondflat's Avatar
9secondflat
bottom line/ grind= synchro's
call randy at rpm, when they are done with their basic rebuild it shifts like butter...
Old Dec 4, 2007 | 07:31 PM
Oldvetter's Avatar
Oldvetter
This happened to my 1998, drain and refill your transmission fluid. I used Amsoil ATC and it went away. I had previously used Mobil 1 Synthetic ATF for 50,000 miles. These transmissions are sensitive to dirty fluid.
Old Dec 4, 2007 | 08:54 PM
speedsk899's Avatar
speedsk899
be careful on what fluid you use in the tranny though. 1999 and older T56 have paper blockers. Synthetic fluid will destroy these and the tranny will have to be rebuilt. The only synthetic you can use in those tranies is Ames Oil
Old Dec 5, 2007 | 06:57 PM
CARRJET's Avatar
CARRJET
Thanks, that may be my problem, 2 years ago I put mobil 1 synthetic ATF in
To gring going into 6th
