KB boost a pump connector HELP
Old Dec 3, 2007 | 07:49 PM
ICUALL's Avatar
ICUALL
Default KB boost a pump connector HELP
Can someone please verify this is the right connector to tap into the large grey wire to connect KB boost a pump to the fuel pump ??????????
Old Dec 3, 2007 | 09:06 PM
ICUALL's Avatar
ICUALL
Default Ttt
Anyone ??????????????
Old Dec 4, 2007 | 11:03 AM
ICUALL's Avatar
ICUALL
Default ttt
ttt
Old Dec 4, 2007 | 12:13 PM
Corvette-Chris's Avatar
Corvette-Chris
St. Jude Donor '08
Pic isnt showing up
Edit: Im not sure...Sorry TTT for ya
Old Dec 4, 2007 | 03:19 PM
ICUALL's Avatar
ICUALL
No problem, I disconnected the connector and applied 12 volts to the pin on the firewall side that coincides with the larger grey wire and the fuel pump fired right up. So I went ahead and cut the wire and spliced the KB boost a pump in and every works as wanted. That connector shown in the picture is the correct one, it is a white connector that is mounted on the passenger side fender next to the battery. Can't really access it unless you pull the battery.
Old Jan 1, 2008 | 01:59 PM
tedandjen's Avatar
tedandjen
Where did you connect the ground wire and tap the tee at?
Old Jan 1, 2008 | 03:07 PM
ICUALL's Avatar
ICUALL
Default ground
I ran the ground to the front passenger side ground point and tapped into my vacuum line on the maggie for the vacuum tee.
Old Jan 1, 2008 | 03:50 PM
B Taylor's Avatar
B Taylor
St. Jude Donor '08
For my 2000, at the same time I installed the Racetronix fuel pump wiring harness. The KB BAP is plug and play to it. Sounds like you got it working though.
To KB boost a pump connector HELP
