Radiator Question
Old Dec 31, 2007 | 11:13 PM
CH.CRAFT's Avatar
CH.CRAFT
Default Radiator Question
Anyone Have Any Technical Info On Aluminum Radiators As To Which Design Is Better, The Round Tubes Or The Flat Tubes ? I Ordered The Dewitts Direct Replacement For My C5 And Did Not Know That It Is Made With The Flat Tubes. I Have A Ron Davis In My 68 Camaro Drag Car Which Has The Round Tubes, And I'm Just Wondering Which Tube Design Transfers Heat Better. Thanks In Advance.
Old Jan 1, 2008 | 12:16 AM
Tom@Dewitt's Avatar
0Tom@Dewitt
Former Vendor
To the best of my knowledge there is no aluminum radiators with round tubes
Old Jan 1, 2008 | 06:38 AM
vettenuts's Avatar
vettenuts
Install the DeWitts, you will see when it arrives it is a work of art
Old Jan 1, 2008 | 11:33 AM
navy99vert's Avatar
navy99vert
Cruise-In VIII Veteran
Did my install last week Very nice
Old Jan 1, 2008 | 01:03 PM
hotwheels57's Avatar
hotwheels57
This is from the rondavisradiators.com website...all of the images of the tubes appear to be this design. I've never used a RON DAVIS radiator in my Corvette, but I've used two of his radiators in tri five Chevy modified cars. They're very high quality products. I believe DRM sells/uses only RON DAVIS products.
Old Jan 1, 2008 | 04:00 PM
B Taylor's Avatar
B Taylor
St. Jude Donor '08
The Dewitt has been excelent for me in the summer AZ heat. Although the radiator alone is not the sole solution to running cooler. Besides a clean air flow to the radiator, you'll want to also consider, coolant mixture, thermostat, fan temp settings and increased airflow. There are a lot of threads on overheating issues.
Old Jan 1, 2008 | 04:08 PM
Cobra4B's Avatar
Cobra4B
CI 3-5-6-7-8 Veteran
I'm running a Dewitts w/ a left side 7-plate oil cooler, and have been for 15,000 miles now. It's a work of art and fit w/o any modifications other than trimming the fan shroud.
To Radiator Question
