LS6 valves question
Old Dec 30, 2007 | 05:55 PM
ParamedicC5's Avatar
ParamedicC5
Default LS6 valves question
So here's the deal. I'm bolting on a set of 243's with patroit dual gold springs, 7.400 push rods, and LG's G5x1"e" cam 228/232 with around little over .600+ lift. My question is will the stock sodium valves handle the pressure or should I just dish out more money and buy a one piece valve. All info and opinions PLEASE!
Old Dec 30, 2007 | 09:04 PM
BATM4N's Avatar
BATM4N
Old Dec 30, 2007 | 11:00 PM
thetorch's Avatar
thetorch
The stock sodium Z06 valves will handle these springs no problem. Don't waste your money on aftermarket valves.
If you go aftermarket you will have to dish some serious coin to get a valve that is anywhere near the weight of the stock valve and less weight is your friend when it comes to valves.
Old Dec 31, 2007 | 01:43 AM
ParamedicC5
sweet that's what I was hoping to hear, I really didn't want to dish out a ton more money, I want to get this swap DONE!
Old Dec 31, 2007 | 01:45 AM
bondoFRC's Avatar
bondoFRC
Cruising
Sodium filled valves will handle the spring pressure. You could get by with a lighter spring and free up some power but its ok to run those if thats what you got. Those will definately keep the valve bounce under control.
Old Jan 1, 2008 | 02:06 AM
ParamedicC5
i do hope so, i'm so not in the mood to buy a new engine should I suck a valve! any other thoughts?
Old Jan 1, 2008 | 04:13 PM
zeevette's Avatar
zeevette
Are you sure you have the sodium filled valves? Just because the heads are 243s, doesn't mean they were from a Z. If they are the Ti valves, I've never heard of anybody having problems adding the dual springs, and I've been reading the tech forums for many years.
To LS6 valves question
