Is Ls1 Water Pump Same As Ls2?
Old Feb 5, 2008 | 12:08 AM
thetaxman's Avatar
thetaxman
Originally Posted by YO-EL
many people use the Evans water pump..
Its manufactured for high volume & high velocity..
1000% better....
http://www.evanscooling.com/main13.htm
600 bucks ?
PASS
Old Feb 5, 2008 | 12:42 AM
Steve D.'s Avatar
Steve D.
Default pumps
The graph I provided were pump flow tests done at Evans test facility in Ct. roughly three years ago. I sent them the pumps to test.
Darton had separate tests done to compare the Evans pump against the stock LS1 pump for flow distribution at Caldwell Developments. The stock pump starts to cavitate around 5,000 pump rpm. The right bank flow also decreases at and above that rpm.
The ten horsepower per gallon a minute is flywheel horsepower. No engine is under constant loading all the way around a road race course. For that reason, you can get away with far less pumping capacity than I used as a reference.
Most highway cars will get away with the electric pump. That because you are not using much more than seventy horsepower +- cruising down the highway at seventy five miles an hour.
The Evans pump retails for $469.95, with pulley. Hard coated pulley is a bit more depending on size. The pump alone is $400.
Steve
Originally Posted by vettenuts
Were these independent tests? Meziere advertises 55 GPM and 35 GPM for their "race pump". Not sure which is included in the plot above.
The 1 GPM/10 HP that you state in your post, is that a rule of thumb to use the curves? Also, is the flywheel or rear wheel hp (since most posts on here usually refer to dyno numbers).
I have also corresponded with Evans on their thermostats and got some interesting information (I also asked about their ceramic coating):
"The stock t-stat from GM will work on our pump. But our t-stat works better as it opens much farther then stock.The stock t-stat, as does ours, allows for coolant flow, but they also have a foot connected to them that when the t-stat opens, this foot blocks off the bypass. Ours does a better job of closing off the bypass and does not allow coolant into the bypass circuit. The stock one does not have that strong of a spring to close off the bypass. As far as the ceramic look goes, I will say that for a part to look like polished aluminum ,it must be totally smoothed out. Our ceramic coated pumps are not smoothed out, just coated, so you have the ease of cleaning it and it is shiny but not a "polished look" shiny. The pump is also coated inside and out before assembly. That gives it protection and better flow capabilities inside as well. I don't have any pics of it online but if you ever seen something that is Jet-Hot coated, that's what the ceramic coating looks like. We also can powder coat any pump to match a specific color too. The difference is only the outside is powder coated, but you have many more colors to choose from....hope this helps...........Tom"
Old Feb 5, 2008 | 01:13 AM
NemesisC5's Avatar
NemesisC5
Steve
Thanks for sharing Steve, the Evans will definetely be going on when my forged engine goes in
Old Feb 5, 2008 | 05:53 AM
vettenuts's Avatar
vettenuts
Any chance you have more information on the pulleys that are available or where to find this information (such as part numbers)? I have looked on their web site and haven't found them. Evans was high on my list before this thread started so this information is very timely for me as well.
Old Feb 19, 2008 | 02:30 PM
Pumba's Avatar
Pumba
I had a very informative conversation this afternoon with Dave at Evans Cooling.
The part number for the stock diameter water pump pulley is EP3916. The price is $170.
Another bit of information that he shared with me was the fact that the LS family of waterpumps have a bypass circuit that at high engine rpms sends hot water back to the oulet size of the radiator. This reduces the efficiency of the already undersize Corvette radiator.
The fix for this bypass is a remote thermostat. David told me that Mustang and Mustang Corbra owners buy these bypass kits for their high output engines by the hundreds. He can only remember selling one of the kits to Corvette owners. It seems our vanity keeps us from fixing our cooling problem.
Old Feb 19, 2008 | 02:37 PM
Pro Street's Avatar
Pro Street
Old Feb 19, 2008 | 04:57 PM
vettenuts's Avatar
vettenuts
I looked and didn't find any information on a remote thermostat. And to think my new GM thermostat showed up today.
Old Feb 19, 2008 | 05:50 PM
Pumba's Avatar
Pumba
Try this link:
http://www.evanscooling.com/main3.htm
From there so to the tab that has THERMOSTATS & CAPS. You will find a remote thermostat shown there. If you are interested, you should call Evans. They do not list all of their parts and part numbers on their web site.
Old Feb 19, 2008 | 07:41 PM
NemesisC5's Avatar
NemesisC5
Another bit of information that he shared with me was the fact that the LS-family waterpump has a bypass circuit that at high engine rpms sends hot water back to the oulet size of the radiator. This reduces the efficiency of the already undersize Corvette radiator.
The fix for this bypass is a remote thermostat. Davd told me that Mustang and Mustang Corbra owners buy these bypass kits for their high output engines by the hundreds. He can only remember selling one of the kits to Corvette owners. It seems our vanity keeps us from fixing our cooling problem.
Do you run a Evans pump on your car?....Man, the "bypass at high rev" thing sounds amazing
Old Feb 19, 2008 | 09:31 PM
Pumba's Avatar
Pumba
No I do not. Today I ordered from Evans the following items:
1) LS High Output Water Pump -------- p/n EP3913
2) Stock-size Water Pump Pulley ------ p/n EP3916
3) 175 degree F Remote Thermostat - p/n E3006
4) Thermostat Install Kit --------------- p/n E3052
5) LS Heater Hose Shutoff Kit --------- p/n E2004
These items will even the side-to-side coolant flow in my engine, increase the volume of coolant flow per minute, feed the engine only coolant from the cold side of the radiator - not the hot bypass coolant, and allow me to turn off the hot coolant from the heater core when I go to the track.
Old Feb 19, 2008 | 09:46 PM
2MCHPWR's Avatar
2MCHPWR
Can you post up pics of your install process?
Old Feb 19, 2008 | 11:54 PM
NemesisC5's Avatar
NemesisC5
1) LS High Output Water Pump ------ p/n EP3913
2) Stock-size Water Pump Pulley ---- p/n EP3916
4) Thermostat Install Kit ------------ p/n E3052
5) LS Heater Hose Shutoff Kit ------- p/n E2004
Very Nice upgrade Please post results in a thread (and PM me a link if you don't mind)
Old Feb 20, 2008 | 05:46 AM
  #33
vettenuts's Avatar
vettenuts
I agree, this sounds worthy of its own thread
Old Feb 20, 2008 | 11:46 AM
  #34
Pumba's Avatar
Pumba
My Z06 is in storage for the winter. I will be taking it out of storage in early April.
At that time I am going to install the Evans Cooling products, along with a new Fidanza dual-disc clutch, L.G. Motorsports trans-diff cooler assembly, and have RPM Transmissions rebuild my diff with a new micro-polished 4.10:1 ring and pinion and a Quaife differential.
I will post pictures at that time.
Old Feb 20, 2008 | 12:34 PM
  #35
vettenuts's Avatar
vettenuts
I would love to get feedback on the Fidanza as well. I considered them when I installed my Tex last year but they weren't quite in production yet. April is when I start mine as well.
Old Aug 1, 2009 | 11:07 PM
  #36
NemesisC5's Avatar
NemesisC5
Any good results to post from this? I had the link to this thread saved for follow up
Old Aug 3, 2009 | 05:31 AM
  #37
intoc6s's Avatar
intoc6s
I have an electric Meziere pump that apparently is a POS on my 427 and it only gets up to 200* if its close to 100* outside and im running it hard. Never gets any hotter than 200.....(180 thermostat-btw) Explain that one....
To Is Ls1 Water Pump Same As Ls2?
Old Aug 3, 2009 | 08:04 PM
  #38
Pumba's Avatar
Pumba
First, the Fidanza dual-disc clutch is doing just fine. Very smooth engagement, no chattering, and it holds everything I throw at it.
Next, the Evans pump and heater bypass valve are functioning as advertised. On track days my coolant temperatures have dropped by about 5 degreees F when shutting off the water flow to the heater.
Old Aug 3, 2009 | 08:31 PM
  #39
NemesisC5's Avatar
NemesisC5
Jim, How much did running your heater on track days lower your coolant temps...just need a baseline to subtract the 5* from
Old Aug 4, 2009 | 06:32 AM
  #40
Pumba's Avatar
Pumba
Scotty,
I did not run my heater during track days up here in Michigan. On a 85 degree F day, my water usually ran 210 to 215 degrees F with my Ron Davis Racing Radiator and my oil ran 235 degrees F. With the heater valve closed, my water now runs about 207 to 212 degrees F. No change in the oil.
