Reverse lock-out
Old Dec 5, 2007 | 01:17 PM
phillyroket's Avatar
phillyroket
Cruising
Default Reverse lock-out
Has anyone had any trouble with the reverse lock-out. I can shift into reverse at a high speed. It doesn't happen all the time ... Any help would be greatly appreciated.
thanks'
Rocket
Old Dec 5, 2007 | 01:31 PM
TM-Z06's Avatar
TM-Z06
Stock shifter? or Aftermarket?
jedblanks's Avatar
jedblanks
ouch!
Old Dec 5, 2007 | 05:28 PM
BELVIN20's Avatar
BELVIN20
Same problem with 2000 Vert MN6, happens every once and a while. Stock shifter.
Old Dec 5, 2007 | 06:37 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Bad reverse lockout solenoid.
Old Dec 5, 2007 | 09:54 PM
Bill Dearborn's Avatar
Bill Dearborn
The reverse lockout solenoid has a spring that can be overridden in case the solenoid fails in the lockout position. If you hit 5th gear hard enough you can override that spring.
Bill
Old Dec 5, 2007 | 10:15 PM
Jim2003's Avatar
Jim2003
Mine went south. It was replaced under warrenty. It is a real pain in the butt to get too. It is on top of the tranny. I have not zero problems with the new part.
Old Dec 6, 2007 | 02:32 PM
phillyroket
Cruising
Default Reverse lockout
I had the reverse lockout solenoid replaced about 2 years ago when it was still under warranty...didn't last...in fact don't know if was really fixed because it happens once in a while...
Thanks for the replies...This is my second C5 and most of the same problems ..except the first was automatic. Electricial and fuel gauge problems but I found that if I stay with Shell gas ... no fuel gauge problems. Of course electricial was a bad ground in the front door area which controlled the front door module. The ground pin was loose but discovered this after the new door module. I also replace the ABS computer and temp switch ..which wasn't cheap. The Partsladi in Florida gave me a great price for the parts and the dealer installed them at a regular labor price...
I am new to Texas anyone in the area with some the same problems..drop me a line...
Thanks for the imput.
Rocket
Old Dec 6, 2007 | 04:26 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Rocket
How did you get a your user name ? Are you from the Phila, PA area ?
I live out in the King of Prussia Area.
You should only be able to go into reverse when your forward speed is less than 3 mph.
I would check my connections first.
To Reverse lock-out
