Intake Swap
Old Dec 5, 2007 | 05:46 PM
brit2001's Avatar
brit2001
Default Intake Swap
I have a 01 and my buddy has a 00. I bought a new intake and throtle body and was wondering if my old intake and throttle bodywill work on his car.
Old Dec 5, 2007 | 05:53 PM
PA_BLUE_C6's Avatar
PA_BLUE_C6
St. Jude Donor '05-'10-'12, '15
Yes, it is a better breathing intake
Old Dec 5, 2007 | 09:31 PM
Russ K's Avatar
Russ K
The 01 is an LS6 intake. In order to install it on the 2000, you need to order the 01/LS6 coolant cross over pipe & rear coolant block off plugs.
Russ Kemp
Old Dec 5, 2007 | 10:31 PM
JesseB's Avatar
JesseB
St. Jude Donor '08
Russ Kemp
01 could still have LS1, my 02 is LS1
Old Dec 5, 2007 | 11:02 PM
SLPRC5's Avatar
SLPRC5
RU sure??? LS6 intakes on LS1 engine since 01.
Old Dec 5, 2007 | 11:17 PM
ILM-Express's Avatar
ILM-Express
MFIC
Look at the bottom of the manifold
Flat bottom LS6
Concave Bottom LS1
Old Dec 5, 2007 | 11:51 PM
'VETTE PHASE's Avatar
'VETTE PHASE
Cruise-In VIII Veteran
I hope you didn't buy an LS6 intake, your car came with one stock. If you did, just sell it to your buddy, it's good for about 10-12 hp on his car. And if you bought an LS2, it doesn't flow as well as the LS6.
Throttle bodies are the same.
It's an LS1 motor, but it has an LS6 intake from the factory.
Old Dec 6, 2007 | 12:39 AM
SLPRC5's Avatar
SLPRC5
Old Dec 11, 2007 | 05:55 PM
brit2001's Avatar
brit2001
Thanks guys, My computer crapped out on me right after I posted and I just got it running again. I bought a BBK intake and throttle body. I'll pass the info to my buddy. Thanks again
To Intake Swap
