LS6 valvecovers
Old Dec 5, 2007 | 08:43 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
Default LS6 valvecovers
Other than the oil fill cap, do the LS6 valvecovers have any other ports/fittings on them?
I'm just going by memory (since my car is in storage and not here at the moment) that the only ports on each of the LS1 valvecovers are both for PCV, correct?.
I'm converting to the LS6 PCV system/valley cover, and having some custom valvecovers made....just want to make sure I don't need provisions for anything other than the oil fill.
Old Dec 6, 2007 | 12:02 AM
zeevette's Avatar
zeevette
The passenger side cover has a vent tube, and the driver's side doesn't.
Old Dec 6, 2007 | 12:33 AM
LoneStarFRC's Avatar
LoneStarFRC
+1 All you need is oil fill and one fresh air tube (or fitting for it) on the passenger side.
Old Dec 6, 2007 | 05:32 AM
vettenuts's Avatar
vettenuts
I am doing the same swap in the spring. There is a vent on the back of the driver's side, but it comes with a cap and isn't used. The passenger side still has the single pipe for connecting to the throttle body for filtered inlet air for the PCV system.
Old Dec 6, 2007 | 04:03 PM
Y2Kvert4me's Avatar
Y2Kvert4me
St. Jude Donor '03
Thanks for the responses.
This is the 90* tube that comes out the top of the valve cover, correct?
Would there be any potential issues in moving the location of this outlet fitting, or possibly tapping it off the side of the oil filler tube? (If I even put the filler tube there, I may relocate it as well).
The valve covers are being machined out of solid blocks of aluminum, I have the freedom to make them anyway I'd like....just trying to keep everything as clean looking as possible.
Old Dec 6, 2007 | 04:09 PM
zeevette's Avatar
zeevette
Don't see why not... I've got mine routed to a Tee, and into a catch can.
Old Dec 6, 2007 | 04:11 PM
LoneStarFRC
You could probably re-locate it. The only thing I can think of that you may want to consider are any baffle issues. Check the underside of a stock cover and see if that fresh air tube is behind a baffle plate. Been so long since I've seen the underside of a passenger side cover I can't recall. There's a lot of oil being thrown around inside from the rockers, etc. I'm not saying the oil would make it's way up into the tube and then into the throttle body necessarily, but it could contaminate any rubber tube attached in close proximity to a rocker that's slinging oil. I can't think of any good reason it couldn't be connected to the oil fill tube.
HTH
Old Dec 6, 2007 | 04:44 PM
vettenuts's Avatar
vettenuts
Oil fill tube would raise it up some from the valve cover and likely be less prone to taking oil back into the intake tract during high revs and corners.
Old Dec 9, 2007 | 04:48 PM
Y2Kvert4me's Avatar
Y2Kvert4me
St. Jude Donor '03
One last question...
I was just told that the 90mm LS2 TB doesn't have a provision for this supply line into the valvecover. Is that correct?
Vettenuts, I know you are running a 90mm FAST setup.. how do you get metered air into the engine for the PCV system if this line no longer connects to the TB?
Old Dec 9, 2007 | 05:21 PM
Y2Kvert4me's Avatar
Y2Kvert4me
St. Jude Donor '03
Nevermind, found a thread addressing the 90mm PCV topic.
Old Dec 9, 2007 | 06:00 PM
Mike Mercury's Avatar
Mike Mercury
on the LS1, there's an oil spash plate on the underneath side drivers cover, and two small splash boxes on the underneath side of the passengers. So no; you don't want to just randomly drill a hole and place a fitting there.
pics here: http://forums.corvetteforum.com/show....php?t=1595822
Old Dec 9, 2007 | 06:14 PM
Y2Kvert4me's Avatar
Y2Kvert4me
St. Jude Donor '03
Originally Posted by Mike Mercury
on the LS1, there's a spash plate on the drivers side cover, and two small splash boxes on the passengers side. So no; you don't want to just randomly drill a hole and place a fitting there.
ref: http://forums.corvetteforum.com/show....php?t=1595822
Interesting, and thank you.
I'm now wondering if I can just tap a fresh air feed from the airbridge directly into the valley cover, and skip valve cover fittings entirely.
Otherwise, tapping off the side of the oil fill tube would also function the same as baffling inside the cover. It's not like the oil is under pressure at that point anyways, it's just being splashed around. Take your oil cap off with the engine running, see how much oil comes up the tube?
Old Dec 9, 2007 | 06:21 PM
Chalky's Avatar
Chalky
Tom:
Just saw this. Great minds think alike.
Got a link to 90mm PCV topic?
Old Dec 9, 2007 | 06:27 PM
Y2Kvert4me's Avatar
Y2Kvert4me
St. Jude Donor '03
Originally Posted by Chalky
Tom:
Hey Dave,
This answered my questions...
http://forums.corvetteforum.com/show....php?t=1657403
Cliff notes; If running a MAF, you'd want to tap into either the airbridge, or the coupler for this feed line into the valve cover to prevent any un-metered air eventually entering the intake.
If running OLSD, then just a simple breather filter would work too.
Old Dec 9, 2007 | 07:10 PM
Chalky's Avatar
Chalky
Just curious but how is the air supply line configured with the LS2 motor?
Old Dec 9, 2007 | 07:59 PM
Y2Kvert4me's Avatar
Y2Kvert4me
St. Jude Donor '03
Seems to come from the coupler between the MAF and TB.
Old Dec 9, 2007 | 08:54 PM
LoneStarFRC
GM part # 12571634 "Tube, pcv"
To LS6 valvecovers
