Headlight issue!
Old Dec 6, 2007 | 11:59 PM
jerryberry269's Avatar
jerryberry269
2nd Gear
Default Headlight issue!
When I turn my lights on, they go to the correct place! But when I turn them off, my drivers light goes about 2/3d's of the way back up! Is there an adjustment? Or is it timming in the actuator motor? 2001 zo6
Old Dec 7, 2007 | 09:39 AM
lionelhutz's Avatar
lionelhutz
Take the surrond off the headlight. You'll see there is a metal tab with a white plastic end. The arm on the motor is supposed to hit that when the light is down. I'm betting it is going past and rotating until it hits the back side of the stop for the raised position (or some other part). I've read the fix is to put a washer on each of the 3 bolts holding the motor between the motor and bracket it's mounted on.
Peter
Old Dec 7, 2007 | 04:41 PM
DeeGee's Avatar
DeeGee
Its a fairly common issue
heres the TSB
Number: 00-08-42-002
Subject: Left Headlamp Door Does Not Stay Closed (Shim Headlamp Door Motor/Actuator and Replace Insulators)
Model Year: 2000 Chevrolet Corvette
Condition
Some customers may comment that the left front headlamp door does not remain closed after the headlamps are turned off. Others may comment
that the left headlamp door closes when the headlamps are turned off, but then reopens. In either case, the right headlamp door operates properly.
Correction
Important
The following information applies to the left front headlamp door motor/actuator only. It does not apply to and should not be performed on the right front headlamp door motor/actuator.
Install one washer (2) between the left headlamp door motor/actuator (1) and the mounting bracket (3) at each of the three attaching bolt locations. Also replace the insulator (4) on each of the two mounting bracket travel stop tabs (5) as shown. For information on headlamp motor/actuator removal, see the Headlamp Motor/Actuator
Replacement procedure in the Lighting sub-section of Body & Accessories in the appropriate Service Manual.
Parts Information
Part Number Description Qty Per Vehicle
11505463 Washer 3
16524060 Insulator 2
Old Dec 7, 2007 | 04:54 PM
ICUALL's Avatar
ICUALL
Default Insulator
Gene has the replacement insulators listed !
Part Number: 16524060 List Price Core Price Your Price
INSULATOR
$6.00 $0.00 $4.57
http://www.gmpartshouse.com/
To Headlight issue!
