MAF Question
Old Dec 7, 2007 | 08:51 AM
vredvet's Avatar
vredvet
Default MAF Question
At what point should we consider relacing the stock MAF with one of the performance MAF's? Thanks.
Old Dec 7, 2007 | 09:06 AM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Unless the stock one is broken, don't. One of the biggest wastes of money. The computer will relean the "performance gain" you will get more air flow, that is about it.
For the cost of the MAF, get a dyno tune, well worth the money than an MAF. IMHO
Old Dec 7, 2007 | 10:00 AM
TheRadioFlyer97's Avatar
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
Only if you're running 600+ RWHP should you even think about it. Some FI applications may need one. If you're at this point, talk to your tuner about which one you'll need.
Old Dec 7, 2007 | 10:04 AM
INTHERED's Avatar
INTHERED
When you max out the one you have.
Do a scan with your hptuner and go wot if it flatlines its maxed out
Old Dec 7, 2007 | 12:20 PM
Zenak's Avatar
Zenak
Terminal Vette Addict
depends on your stock MAF. I had the stock older style one with METAL housing. I got an aftermarket composite housing with no honey comb and wider opening, better aerodynamics. Cost with shipping about um 25 to 30 bucks?
Took apart the stock one, updated the housing (the metal on the orig also acts as a heat sink robbing HP) and walla. INSTANT feel in the throttle response. Temps ran about 1 degree lower.
If you have a metal MAF housing, change it before you do a dyno tune! While your there get a new Cold Air / Ram air intake.
Old Dec 7, 2007 | 12:44 PM
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
I'm curious how much the metal housing affects the intake. I recently swapped mine out for one and i can't remember if it was before or after the tune.
Old Dec 7, 2007 | 09:30 PM
TLewis4095's Avatar
TLewis4095
Man! Pretty much all good info given from each poster....not much to add. Good job guy's!
To MAF Question
