MAF Screen Removal
Old Nov 23, 2001 | 03:43 PM
rdochterman's Avatar
rdochterman
Default MAF Screen Removal
I have a 98, and I want to remove the screen from the mass air flow sensor. Everyone says it's easy, but my problem is that my airbox seems to be attached to the front of the car with two screws (of some kind) way down low (hard to even reach). Is this normal? I can get everything else loose & ready to take out, but I cannot seperate the portion of the airbox closest to the engine from the MAF until I get it all out, right? When I look at the installation instructions from the Vortex Rammer, it just says to unhook all of the junk I've unhooked, and pull the whole mess out. No mention of these screws.
Help!
Old Nov 23, 2001 | 03:53 PM
1999 White C5 Coupe's Avatar
1999 White C5 Coupe
Default Re: MAF Screen Removal (rdochterman)
rdochterman,
The C5 air box is mounted to two "studs" that fit into two rubber gromments, which are mounted in the air box lid. the studs are fastened to the front bumper brace.
The easiest way to loosen and remove the air box assembly is to open the hood and reach between the front of the hood and the front filler panel. Use both hands, one on each side of the air box, and push toward the engine. The air box will "pop off" the studs and enable you to remove the entire assembly from the engine compartment side. Also loosen the clamp at the throttle body and the two electical connections. Remove the entire assembly.
The rubber gromments often pop off the air box and fall below. Do not loose them - they are easily pushed back into the air box holes. I put a little silicone dielectric grease onto the inside of the gromments, so that they slide onto the studs easier.
Good luck.
1999 White C5 Coupe
Old Nov 23, 2001 | 04:11 PM
kewlbrz's Avatar
kewlbrz
Cruise-In II Veteran
Cruise-In III Veteran
Since you have a 98, I would recommend first trying the Breathless MAF ends with air foils. That way you do not have to hack out your screen from the factory maf end. Plus youll increase your airflow capability. A MAF Translator may be needed to optimize that mod.
Old Nov 23, 2001 | 04:18 PM
rdochterman
Default Re: MAF Screen Removal (1999 White C5 Coupe)
Thanks, you guys! I will try this right away.
Old Nov 25, 2001 | 01:22 PM
carpe dm's Avatar
carpe dm
Kewlbrz is right; try a set of MAF ends and save your stockers in case you want/need to return to the way God made the car.... :) BTW, welcome to the Forum. Please post again and let us know how you are doing with that mod. :seeya
[Modified by carpe dm, 11:24 AM 11/25/2001]
Old Nov 25, 2001 | 01:37 PM
robsvette's Avatar
robsvette
Default Re: MAF Screen Removal (carpe dm)
definitely listen to kewlbrz!
Old Nov 25, 2001 | 09:02 PM
THEMONEYPIT's Avatar
THEMONEYPIT
I'VE HEARD BAD THINGS ABOUT REMOVING THE SCREENS. SOMETHING ABOUT THE CAR WILL RUN TO LEAN? I WAS GOING TO DO THE SAME THING AND I WAS STEERED AWAY. CHECK INTO IT!! I AM NOT AN EXPERT, CHECK WITH SOME MORE KNOWLEDGABLE MEMBERS.. :confused:
Old Nov 25, 2001 | 09:48 PM
kewlbrz's Avatar
kewlbrz
Default Re: MAF Screen Removal (THEMONEYPIT)
First of all, turn off your caps lock. It indicates your yelling.
Removing the screen as GM engineering finally got around to doing with the Z06, is an ok mod. Like I said above, it may need some tuning with a maft, but most will be fine.
If you wish to understand what happens to the engine and PCM when performing mods. Please read my write up here first:
http://www.vetteguru.com/mods/howto
[Modified by kewlbrz, 7:49 PM 11/25/2001]
Old Nov 25, 2001 | 11:00 PM
99 The Hard Way's Avatar
99 The Hard Way
I have a 98 with a vortex. I installed it alone, w/ no other mods. I then removed the screen, & there was a noticable difference. No problems at all. I did a relearn & runs awesome. So i decided to try the nylon MAF ends with no foil. It ran like CRAP! Did a relearn & same thing. Put the stock ends back on & ran awesome again. I beleive you need a MAFT to use the ends. The other members have good points, but i felt the need to tell you since we both have 98's. Newer models seem to have more problems when screens are removed. Screen removal also seems to work better with Vortex than with other systems. I say DO it! Hold off on the screens until you get a MAFT. SCOTT
Old Nov 26, 2001 | 11:11 AM
C5 Frank's Avatar
C5 Frank
I pulled my screen on my 99 with 1,000 miles..... I did it on the dyno and saw 8 rwhp across the entire rpm!!!!!! The car runs great and has never spit a code out. I did the same thing to my girlfriends WS6 on the dyno, her T/A picked up 9 rwhp..... runs great as well! It's the only free mod that works and is trouble free! Now I have a few buddies that ported their MAF, and they get codes now and then.... but pulling the screen if done right will not!
To MAF Screen Removal
