Caliper Removal
Old Dec 10, 2007 | 01:09 PM
De_Vette's Avatar
De_Vette
St. Jude Donor '09-'10-'11-'12
Default Caliper Removal
I have read every thread I could find on painting calipers and replacing rotors. I'm going to have my calipers powder coated and I'm looking for any information on how to deal with the brake lines after removing them from the calipers. I also read where someone mentioned the ABS would need to be cycled after putting it all back together, any info on this? Thanks
Old Dec 10, 2007 | 01:29 PM
XXXLTRP's Avatar
XXXLTRP
I'll be doing this soon when I change the brake lines at the same time.
Old Dec 10, 2007 | 01:54 PM
peebee_c5's Avatar
peebee_c5
Mike the Powdercoater ("Corvette Pilot" here on the forum) recommends M10 bolts & nuts, along with your old crush washers.
Worked for me when I spray painted mine.
Old Dec 10, 2007 | 04:35 PM
BATM4N's Avatar
BATM4N
Old Dec 10, 2007 | 05:23 PM
De_Vette's Avatar
De_Vette
Thanks, I will do that, was planning on using Mikes fine service to get them PC'd
Old Dec 10, 2007 | 05:25 PM
2000BSME's Avatar
2000BSME
no need to mess with abs, just bleed your affected calipers.
Old Dec 11, 2007 | 12:29 AM
4DRUSH's Avatar
4DRUSH
If your keeping the same rubber brake lines, just pinch them closed with vice grips and replace caliper, bleed each one as you go.
Old Dec 23, 2007 | 11:10 AM
peebee_c5's Avatar
peebee_c5
Lot's of people recommend against that to avoid damage to the hoses. Can't go wrong with the M10's....
Old Dec 23, 2007 | 11:46 AM
YeloFevr's Avatar
YeloFevr
I, personally, think it is foolish to reuse the original crush washers. Why not just order a set from Gene Culley for a few cents and have the peace of mind that your washers will fully seal the line/caliper connection? That's just me, though.
Old Dec 23, 2007 | 02:49 PM
Bill Dearborn's Avatar
Bill Dearborn
Plug the hoses if possible to keep the brake fluid level from dropping below the Master Cylinder reservoir. If you let the brake fluid level drop below the Master Cylinder you risk getting air into the ABS system which means that you will need to bleed it by taking the car to a shop that has a Tech 2. As for the crush washers I don't want to take business away from Gene but they are very easily obtained from a local auto parts store when you need them. It would cost more to mail them than they are worth.
Bill
Old Dec 23, 2007 | 03:18 PM
YeloFevr's Avatar
YeloFevr
Bill
Wow, I couldn't find these washers to save my life! I checked the auto parts stores and GM dealers and no one could get those for me. Gene was the only person who could help me out.
To Caliper Removal
