I just got my 2008 C6Z06 shifter assembly and wanted to install it on a 2002 C5Z06. Should I install the entire shifter assembly (big block held in with the TORX screws) or just the shifter (piece that is held with the 4 3/8" screws)?
Thanks in advance for any help.
Sunrise
You need to do the whole assembly. It should come that way. You should have to remove three torx screws, and lift out. Search for patches thread on this which has pics. I replaced mine back in July! Great feel. I also did the Antivenom mod to the trans which makes it feel less notchy as well. Enjoy! Don
Sunrise
I did the whole box -- simplest way to do it; no need to open/expose the internals.
Sunrise
Would anyone have the part number for this shifter
Go over to C6 forum and sniff around. I bought one over there about a year and a half ago from a guy who installed an aftermarket shifter. Got the shifter AND **** for $100. It's a good swap.
