Radio security code....
Old Dec 12, 2007 | 11:51 PM
LT1vette's Avatar
LT1vette
Default Radio security code....
I want to take the battery out of the car to store for the winter. Is there a way to find out the security code b4 I unhook the battery? I bought the car used and don't have the code.
Will I have to take the car back to the dealer to get them to unlock the radio in the spring if I don't know the code?
Is there any other problems I'm likely to uncover when I go to install the battery in the spring?
TIA
Old Dec 13, 2007 | 07:19 AM
Tex_Vette's Avatar
Tex_Vette
Just Passin' Thru
I copied this from a post long ago. Perhaps it will help:
The following procedure will give you a new code that you can use instead of your personal code. Using this new code, you can “unlock” your radio and then “re-lock” it with a new code if you wish.
Prerequisites: The radio must be in LOC mode NOT in INOP mode. Let me explain. If you have activated the Theft-Deterrent feature of your radio and lose power, the radio goes into LOC (theftlock) mode. With the ignition on, you must use the MN and HR buttons to enter your personal code in order to unlock it (The instructions are on page 3-27 in your Y2K Owner’s manual). If you fail to enter the correct code eight (8) times, the radio goes into INOP mode. You have to wait an hour with the ignition on before the radio returns to LOC mode (go for a long drive somewhere).
Procedure:
01. Turn the ignition ON (The radio displays LOC)
02. Hold down the Radio Presets 2 and 3 buttons for six seconds
03. The radio display changes from LOC to a three-digit number. Write this number down. Don’t take forever, fifteen seconds max before the next step.
04. Press the AM/FM button
05. The radio display changes to another three-digit number. Write this number to the right of the first one.
06. You now have a six-digit number, the first three digits are from STEP 03 and the last three digits are form STEP 05.
07. Call 1-800-537-5140
08. Press 1, then # (pound). You’ll hear “Invalid Code, try again”
09. Press 139010, then # (pound). You will be asked to enter your four or six digit code followed by * (start)
10. Enter the number from STEP 6, then * (star)
11. Listen to the four-digit number and write it down. It will be repeated twice.
12. Turn the ignition ON (The radio displays LOC)
13. Use the MN and HR buttons to enter the code from STEP 11
14. Press the AM/FM button. The radio display changes to SEC Your radio is now “un-locked” and usable. The Theft-Deterrent feature is STILL active! If you want to disable it, use the instruction on page 3-27 in your Y2K Owner’s manual. Use the code from STEP 11 instead of your personal code.
Note: This tip originated from LOTZAHP, Austin TX (credit must be given where credit is due).
Tex_Vette
Old Dec 13, 2007 | 07:34 AM
rws.1's Avatar
rws.1
That is what this Forum is about.... answers when you need them most
To Radio security code....
