Wheel balance
Old Dec 13, 2007 | 09:02 PM
Allzwell's Avatar
Allzwell
St. Jude 15 Year Donor
Cruise-In VIII Veteran
St. Jude Donor '03 thru '20
Default Wheel balance
What is the max amount of weight that should be used to balance a tire & rim?
Old Dec 14, 2007 | 12:26 AM
thetaxman's Avatar
thetaxman
I don't know if there is a real limit.
I've seen big truck tires take 8 oz. before.
I'd be looking at the tires on my vette funny if they took over 4 oz.
Old Dec 14, 2007 | 07:51 AM
Allzwell's Avatar
Allzwell
Thanks Taxman ...
Any others?
Old Dec 14, 2007 | 02:33 PM
97C5owner's Avatar
97C5owner
I work at the Discount Tire right down the road from you at Monroe and 45. There are several factors which can contribute to an excessive amount of weight on a rim. All tires and rims have imperfections which cause some spots to be heavier than others. These imbalances are magnified with the centrifugal force of the tires speed spinning. This imbalance becomes excessive when the heavy spots in the tire and rim are in close proximity to one another. Adding an excessive amount of weight to compensate is not the best option to correct the imbalance. The problem will be more accurately (and permanantly) corrected by turning the tire on the rim so that the imbalances offset one another thereby minimizing the amount of weight necessary to compensate. An experienced technician on a Coats 9700 will be able to determine where these heavy spots are, and correct them. Some tires-Goodyears especially- are notorious for excessive imperfections, and I have warrantied several units out for this reason over the 13 years I have been with the company.
How much weight was added to your rim? What kind of tire are you running?
Old Dec 14, 2007 | 02:37 PM
ericdwong's Avatar
ericdwong
Coats makes a 9700? I thought it was Hunter with the GSP9700 thats supposed to minimize the rim and the tire's heavy/light spots by rotating the tire on the rim....
I've seen like 4 oz of weight on C5 repro wheels before. My Mag wheels needed .25 oz on one and 1.5 oz on the other.
Old Dec 14, 2007 | 04:22 PM
pec98's Avatar
pec98
I once had a problem witha a B F Goodrich tire and the factory rep told me that they only allowed 3 oz MAX. However I purchased replica wheels from Discount Tire and after seeing them try to install 6 oz of lead I complained. After all the crap they removed the tire and spun the rim bare ( NO TIRE) and it was 3 oz off. They replaced that rim. To my dismay I'm stuck with four wheels each needing about 3 oz of weight, all on the outside of the wheel I FRICKEN HATE THEM! Thanks discount tire
Old Dec 14, 2007 | 04:42 PM
Allzwell's Avatar
Allzwell
My problem was actually with Discount Tire in Pearland on some new tires I bought for my Denali. My wife took the truck in and I saw it last night. They had installed about 8" of lead around one side of the rim. I called BS on it and she took it back there today. They did rebalance and she called to say that there was very little weight needed once they spun the tires on the rim and rebalanced.
I'll send you a PM, I need a road force balance on my DD. I'll come see you.
Old Dec 14, 2007 | 07:42 PM
pec98's Avatar
pec98
Make sure they just didnt static balance the tire. With that they could put the weight on the inside of the tire. Like years ago when they used bubble balance methodes.
Old Dec 14, 2007 | 07:45 PM
JH's Avatar
JH
Road force balance is the only way to go.
Worth the small extra $$ everytime.
Old Dec 14, 2007 | 08:44 PM
thetaxman's Avatar
thetaxman
Rarely needed.
we spin our race cars up to 150 mph w/o an issue.
Old Dec 14, 2007 | 09:45 PM
Janfun's Avatar
Janfun
Do you know anybody who can do a proper balancing/aligning in PA???
Some time ago a tire company (no nasme) adjusted my alignment and balanced wheels. Now it is good up to 130 mph but after that I have some seriouse issues with wibrations. I believe it is because of Z06 rims and not due to Michelin PS2s???
HELP!
Old Dec 15, 2007 | 08:39 AM
rws.1's Avatar
rws.1
Old Dec 15, 2007 | 10:42 AM
Allzwell's Avatar
Allzwell
Problem solved, Thanks everyone
Old Dec 15, 2007 | 11:16 AM
ericdwong's Avatar
ericdwong
HELP!
If you're in Bethleham PA I'd recommend http://www.wheelcollision.com/ They're just up the street from you in Bath PA and use a GSP9700. They can probably recommend an alignment shop too.
Oh yeah, and if the technician doesn't know what he's doing the GSP9700 doesn't help either. Don't ask me how I know Tire balancing are NOT created equal.
To Wheel balance
