Help, I lost the passenger door!
Old Dec 15, 2007 | 03:29 PM
DBLX's Avatar
DBLX
Default Help, I lost the passenger door!
Pull the beast in the garage today, went to put the windows up and the passenger side did nothing. Checked p. door related fuses under the dash, nothing blown. Symptoms; window will not go up or down from either door, p. door will not lock from either door, and p side mirror will not move. My next move would be to check connectors in the door, once I figure out how to get the door panel off. LOL. It was working fine during the drive, then nothing.
Any suggestions would be greatly appreciated.
TIA,
Malcolm
Old Dec 15, 2007 | 04:29 PM
Corvette Don's Avatar
Corvette Don
I have heard of this before, ck the wires going from the actual car into the door through that black groumet (sp?) from whats told the wires it there can split open and "short" out. Thats the first spot to check.
Old Dec 15, 2007 | 04:32 PM
thetaxman's Avatar
thetaxman
wiggle the tube between the door and the chassis
I have to do this once a year
Old Dec 15, 2007 | 05:34 PM
mrm1149's Avatar
mrm1149
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13
I've read that more than once on here...........
Old Dec 15, 2007 | 05:35 PM
hotwheels57's Avatar
hotwheels57
When I read the title, I had a vision of you knocking the door off the hinges pulling into or out of the garage...
Old Dec 15, 2007 | 05:37 PM
Ol'55's Avatar
Ol'55
From: Southern New Jersey, The wet part at the bottom
St. Jude Donor '08-'09-'10
The rubber grommet mentioned above looks like an accordion.
Old Dec 15, 2007 | 06:20 PM
corvettejoe98's Avatar
corvettejoe98
TIA,
Malcolm
same issue on my dads 98 vette with 3k miles, bad motor possibly? we bought a whole new motor assembly, didnt even think to check the fuse, let us know if you get it working again good luck
Old Dec 15, 2007 | 07:53 PM
VinceC5's Avatar
VinceC5
have seen this problem many times, check here:
http://forums.corvetteforum.com/show...&postcount=316
Old Dec 16, 2007 | 12:04 AM
DBLX's Avatar
DBLX
Ill try it in the morning.
Old Dec 16, 2007 | 12:16 AM
Z06ster's Avatar
Z06ster
VinceC5 is right on target. I had the same problem. Basically you need to pry the connector apart and then clean it good with electronic component cleaner and then use DI grease to prevent future corrosion.
The repair is not too terrible in the sense you don't have to pull apart a million things to get to the troublesome connector. However, reaching the connector is a different story. Unless you have very small hands, getting your hands in door jam and effectively using them to work on the connector is a challenge.
Old Dec 16, 2007 | 12:27 AM
2blklt4's Avatar
2blklt4
me too
Old Dec 16, 2007 | 01:40 AM
schmaltzr's Avatar
schmaltzr
TIA,
Malcolm
I thought you left your car in some unsavory place and someone stripped the car of the passenger door or the door fell off for some reason.
Old Dec 16, 2007 | 12:39 PM
DBLX's Avatar
DBLX
Default Well?
I wiggled the harness and magically the window and door lock now works, lol! now for the trick. Is the connector in the body, or in the door? There must be an easier way to pull the boot off? Is it usually a loose connection/conector or am i a victim of corrosion? I know its hard to say without seeing it, but I was just wondering what the typical problem was...
THANKS,
MJ
Old Dec 16, 2007 | 02:26 PM
VinceC5's Avatar
VinceC5
The problem is actually the exposed wire in the 2nd pic. It gets grounded. All you have to do is insulate it. The boot is the easiest thing to remove and put back. You can do this - boot off, pull on the wiring and then just tape it up. You could actually just pull on the boot by the body and get the wiring away from the ground point. I did that about 3 months ago and the problem hasn't come back.
Old Dec 16, 2007 | 02:28 PM
VinceC5's Avatar
VinceC5
It wasn't me -- thank Bill Curlee !!
Old Dec 16, 2007 | 06:10 PM
thetaxman's Avatar
thetaxman
THANKS,
MJ
I never bothered
Old Dec 17, 2007 | 12:37 PM
johncbourg's Avatar
johncbourg
St. Jude Donor '09
Sorry for the laughter, but when you said lost the door I thought literally
It reminded me of a day I'll never forget back in high school in the late 80's.
This guy used to love and brag how great his Pontiac Grand Prix was, and he pulled up to one of our crazy weekend parties.
Well his lady attempted to get out of the car, and the freaking door completly fell off the car
Right in front of all my me and my buds
We could not stop laughing for hours.
Sorry about your issues though
To Help, I lost the passenger door!
Old Dec 17, 2007 | 05:06 PM
vetterdstr's Avatar
vetterdstr
CA Events Coordinator
When that happened to my car the sensor in the door had gone bad. My gauges in the dashboard stopped working as well even though the car ran fine.
Old Dec 29, 2007 | 01:46 PM
DBLX's Avatar
DBLX
What a pain in the butt!
Old Dec 29, 2007 | 02:52 PM
vetterdstr's Avatar
vetterdstr
Yes it was!! I found it hard to believe a door sensor could take out my passenger window as well as the gauges in the dash board at the same time.
