IPC repair
Old Dec 15, 2007 | 05:28 PM
GS023's Avatar
GS023
Default IPC repair
OK
I am having issues with battery drain on my 02 cv. After doing the "amp meter pull fuses test" it looks as if there may be an issue with the instrument panel cluster. I understand these can be sent off for repair. Anyone know anything about this? Any help would be appreciated.
Old Dec 17, 2007 | 05:19 AM
GS023's Avatar
GS023
ttt
Old Dec 18, 2007 | 07:05 AM
GS023's Avatar
GS023
Help!!!!
Old Dec 18, 2007 | 08:33 AM
lucky131969's Avatar
lucky131969
How about some more info? What fuses did you pull, and what was the subsequent current drop?
Old Dec 18, 2007 | 09:49 AM
GS023's Avatar
GS023
After car is completely asleep the current draw never drops below 45 ma's. The fuse that dropped the ma's to around 3 was #25 mini fuse in the footwell box. The cover shows that fuse covers BCM 1 and IPC.
Old Dec 19, 2007 | 08:04 AM
Tomulrich's Avatar
Tomulrich
the IPC cannot be repaired (if that is the problem). It is a non servicable item.....replacement is option
Tom
To IPC repair
