Cam handle
Old Dec 18, 2007 | 08:36 PM
vettenuts's Avatar
vettenuts
Default Cam handle
Anyone found a cam handle that fits LS1 cams? I have been looking but they say "not for hydraulic" or something else. Just trying to add this tool to the mix.
Old Dec 18, 2007 | 09:14 PM
500hp's Avatar
500hp
One of the LS1's longer water pump bolts works great as a cam handle.
Old Dec 18, 2007 | 09:43 PM
chriswtx's Avatar
chriswtx
I use 2 of them...
Old Dec 19, 2007 | 06:11 AM
vettenuts's Avatar
vettenuts
Yes, I made two special bolts for this but the handle looks easier to deal with. Maybe I will just wrap my bolts in tape. Just trying to add to my toolbox.
Old Dec 19, 2007 | 08:24 AM
LDB C5's Avatar
LDB C5
I am getting ready to swap my cam and have been looking for a tool like this as well. What I have decided to try is to get a long (`6") bolt, a couple of washers and a piece of pipe. You will only need the handle for first bit of removal; and the last bit of installation so I think this should work. If anyone has a better idea; please post up.
Old Dec 19, 2007 | 08:33 AM
vettenuts's Avatar
vettenuts
I have been using two carriage bolts that I ran a metric die down for about 1/2" so it would fit the cam. Threads are sharp though but I did end up with something longer than the water pump bolts.
Old Dec 19, 2007 | 09:02 AM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
The cam is hollow so I use a long screwdriver inserted in the center, works great and can be used to loosen and tighten screws and makes a pretty darn good chisel.
Old Dec 19, 2007 | 09:29 AM
vettenuts's Avatar
vettenuts
I have a Crane cam in the car now and they are not hollow.
To Cam handle
