98 Lingenfelter starting issues
Here's one guy selling the DVD.
http://forums.corvetteforum.com/show...service+manual
U1255 The BCM and EBTCM did not receive info from the PCM.
Try disconnecting the harness that was causing the relay to chatter/buzz, and see if PCM comm is
restored.
I know you said you checked the grounds, but did you open them up and look inside, as shown in the following link.? You mentioned you were working on the front end of the car. You didn't inadvertantly disconnect one of the grounds while you were doing other repairs?
http://forums.corvetteforum.com/show...ighlight=u1255
Also check the data star connectors 1 ond 2 for a bad connection.
While the problem your seeing doesn't look like it's being caused by a shorted wire in the door, that has caused some weird problems in the past, and is fairly common problem, and easily tested. Wiggle the harness around where it comes through the drivers door and see if the symptoms change.
Taken from the manual:
Condition to set the DTC
* The BCM didn't receive a state of health (SOH) from the PCM when the ignition was first turned on.
* The BCM detected an open or short( to ground or voltage ) on the serial data line circuit.
Action taken when DTC sets
*U1255 stored in BCM memory
*The PCM will not allow fuel enable processing to occur. (cranks but won't run)
* No driver warning massage displayed on the DIC.
*BCM may substitute default values for certain systems
Diagnostic Aids
*If the U1255 is stored in the BCM and other systems capable of storing that code, check for a short to ground or voltage on that serial data line.
*If other systems do not have the same code, check for an open in the serial data line between the BCM and PCM or IPC (instrument panel cluster)
I bought the 1998 service manuals awhile back when i began work on the car. But its like reading another language at times ha. I get the gist of what its telling me to do but not always to the point.
The grounds are where they should be bolted down and clean inside and out. checked and double checked that one.
Data star connections? Are these the two bulk connectors plugged into the pcm?
I recieved the u1255 code from multiple sources.
Riddle me this one... The battery neg wire that grounds to the engine block also has two smaller wires grounding at that location. Who knows what wires they are? I do believe i have found my problem they were both seperated how it happened... act of god?
Did the ground wire fix your problem? If that was the wire to ground G104 that wasn't connected, it goes to splice pack 208 which provides grounds for numerous components, including the data link connector, instrument cluster and BCM along with other things. Refer to Vol 3 Ground Distribution Schematic Cell 14, page 8-441 in my '99 manual. Yours may be different. Also, the data star connector info is in the very front of volume 3.
Alright the snow has hit and im going out plowing so what i found in the meantime.
When connecting the wires together and turning the key to the on position the relay stops its erratic nosies and and the fuel pumps prime!!! That could have been the best noise i have ever heard ha
Did not get a chance to run the codes or to actually fix that wire yet so sunday ill get out there and actually test everything.
Thanks for all your help! Hey greg you from aorund chicago? I feel i need to buy you a beer or seomthing you have been a great help to a newbie like myself.
It would help if you would fill out your sig, there is a lot of knowledge/help here in chicago
but now the question is can you get the wire loom tape from gm? I did not open it completely just here and there to follow the wire to its destination. So to do this right i would like to close it back up like i was never there.
It takes alot of current to get that wire hot enough to melt the insulation. Hopefully that hasn't stressed the circuitry in the PCM. When you get it back together, I would check to be sure those wires aren't getting warm. The burnt wire might be the result of the problem, not the cause. Hopefully everything is OK. I hope some of the info I sent was useful, or at least got you thinking about the possible solution to the problem.
It sounds like you will be starting the new year off right. Now get that bad boy finished up. It will be springtime before you know it.
