Climate Control Repair
Old Dec 16, 2007 | 08:54 PM
WAVEBK's Avatar
WAVEBK
1st Gear
Default Climate Control Repair
Thanks to those who came before,this repair works as per listed info.
I did alter the method buy using a butter knife tip to check with light pressure the resistors and only resoldered the ones that flipped up.
Old Dec 17, 2007 | 03:08 AM
tstar's Avatar
tstar
St. Jude Donor '11-'12-'13-'14-'15
I'd recommend re-soldering all of them regardless. Sometimes a cold solder joint or a high resistenance joint will seem firmly attached but isn't internally.
Nice job of coming up with a quick check though!
Old Dec 19, 2007 | 09:37 AM
KEV21's Avatar
KEV21
I had the same problem, and re-soldered mine also. Works like new!
This forum is priceless!
Old Dec 19, 2007 | 10:04 AM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
Best to do all of them just in case the others decide to falter
Did all mine when I was in there!
Thanks,Matt
To Climate Control Repair
