View Poll Results: Should I change my stock heads to Patriot stage 2 ?
Yes
68.97%
No
17.24%
Maybe explain below, please
13.79%
Multiple Choice Poll. Voters: 29. You may not vote on this poll
Patriot Performance stage 2 heads
Old Dec 18, 2007 | 06:55 AM
ILM-Express's Avatar
ILM-Express
MFIC
Default Patriot Performance stage 2 heads
I have a stock 99 with outside bolt on only I was looking at the patriot performance heads stage 2 part number 2009, I can get them pretty cheap what do you guys think ?
I also have 1.8 crane rockers to install with them.
I do not want to change the cam.
Old Dec 18, 2007 | 09:31 AM
AU N EGL's Avatar
AU N EGL
the 241 heads on you 99 are OK but the patriot would be much better.
Now would also be a good time to install a new cam, timing chain and under drive pulley.
Good Luck on your project
Old Dec 18, 2007 | 12:36 PM
BATM4N's Avatar
BATM4N
Ok you must work or have some association to Patriot cause who wouldn't want 30 more HP
Old Dec 18, 2007 | 12:47 PM
AU N EGL's Avatar
AU N EGL
Not me. I have PP243 heads now, took off my PP 241 heads,
Have a set of LPE SWGT PP 243 heads in my basement ( spoken for) and most likely will put on AFR205s on
Old Dec 18, 2007 | 02:12 PM
TLewis4095's Avatar
TLewis4095
Old Dec 18, 2007 | 03:26 PM
vettenuts's Avatar
vettenuts
With no other options, I voted "No". Here is my reasoning:
There are several cases of installation of AFR heads with the stock cam that have produced over 40 hp at the wheels. If you optimize compression and tighten quench with a thinner gaskets, the throttle response and the power will be excellent. Vinci has a test on his web site that was documented in the one of the magazines with just a head swap (at least initially). There are some others also, try google, they will pop up. With the stock cam, and its limited RPM range, you need a set of heads that will take maximum advantage of it and small port AFR's are the way to go in my opinion.
Old Dec 18, 2007 | 04:35 PM
Pumba's Avatar
Pumba
My vote was NO.
I would recommend that you look at Trick Flow's 215 cc head instead. It has better flow numbers and will generally develop more power.
As others has already noted, now would be the time to install a good hydraulic camshaft, Crane and others could recommend one for your use.
I would also install a set of Smith Brothers 3/8 inch x 0.120 inch wall, oil flow restricting chrome-moly pushriods and a Katech timing chain and gear set.
I would not recommend an underdrive crank pulley. (Sorry guys, I have too many years as an automotive engineer looking at cooling, steering response, and electrical demand data to buy into underdrive.)
Good luck with your decision.
Old Dec 18, 2007 | 04:53 PM
black98c5's Avatar
black98c5
You can do cam only but to do heads only is kind of backwards if you ask me. Patriots are a good budget head though.
Old Dec 18, 2007 | 05:16 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
I'll toss in a yes vote.
Let's face it, the $1000 Patriots will add some hp, and if they are the small chamber versions, will give a nice bump in compression.
We all know the Trickflows are very nice, but by the time they are on your car, you'll have dropped $3k, and still not have a cam or any of the supporting components that can take advantage of what those heads have to offer. It's pretty obvious you're choosing the Patriot's because they are cheap, and they work, and if your long term goals won't continue building the engine up, then yes, they are a terrific value.
Now, if your long term goals included a sizable cam, a FAST intake, etc, then saving for some better heads to compliment your end goal, that would make a lot more sense.
Finally, there is very little shared labor between a head install, and a cam install, so from a labor aspect, there really is no "as long as you're there" or "now's the time to do the cam too" logic. A cam install and a head install are two very different jobs.
Old Dec 18, 2007 | 05:50 PM
frodo84's Avatar
frodo84
Uneducated autodidact
It all depends on what you are looking for....if you want a "max effort" car then buy better heads. If you are talking about a street car, a driver, then for the money I would be willing to give up a few horsepower for the budget heads. Everyone will argue about how many a "few horsepower" are, but no one will be able to prove any number they come up with anyway.
Old Dec 19, 2007 | 01:01 AM
Thickraybans's Avatar
Thickraybans
I voted maybe.I picked up 41hp with Patriot stg2 LS6 heads.The graphs are here http://forums.corvetteforum.com/show...post1562962326
If I were not going to change the cam I would put the money toward gears.
Old Dec 19, 2007 | 01:29 AM
Corvette Don's Avatar
Corvette Don
Damn I have the same cam, I really need to get rid of my stock heads.
ILM-Express, I would spring for the heads, its a good deal and if you feel you need a change 2k miles later than you would still be able to get $800 for them. I really want trick flows but they are about $1500 MORE than the PP heads
Old Dec 19, 2007 | 10:19 AM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
They will flow much better! and you'll gain HP and TQ by swapping them out!
They are a good head for a good price! make good numbers!
Thanks,Matt
To Patriot Performance stage 2 heads
