Secret DTC Code
Old Dec 16, 2007 | 09:04 PM
Bell's Avatar
Bell
Default Secret DTC Code
A few days ago, my battery positive cable decided to pull an intermittent disengagement. Just a click on attempt to start. No tools. Manual twisting force got enough engagement that it started right up. I've had battery power loss before and know that this usually throws lots of codes because all of the modules in the car are monitoring voltages. Any time there is an unexpected voltage (too low or too high) and a code will set.
Today I found DTC code B2809 for the BCM. I wrote it down, cleared it and it has not returned. I suspect the battery problem the other day. Then I went to my service manual to see what this code is. IT'S NOT IN MY 2002 SERVICE MANUAL!!!!. I came to CF and did a search. Only found one other post with this code and it also was a battery related problem. That person also cleared the code and it hasn't returned.
I went to DC (the other corvette forum) because they list all the DTC codes for every year C5. It may be here on CF but I can't find it. Over there, I searched in every single year 1998 to 2002 (my car is 02). B2809 is not listed for any year!!!!
What is this code?????? Obviously it's a secret code that GM reserves for those with the secret decoder ring.
Anybody else ever seen this or know what it is?
Old Dec 17, 2007 | 03:05 AM
tstar's Avatar
tstar
St. Jude Donor '11-'12-'13-'14-'15
I ran a check on my DVD service manual and came up with nothing, here are the two closest;
DTC B2805 Steering Whl Controls HVAC Sw CKT Malf
DTC B2810 Steering Whl Ctrl Entertainment CKT Malf
Something with the steering wheel maybe, what did you do? Fess up, you cut out the embossed emblem and embedded EL wire didn't you?
Old Dec 17, 2007 | 10:13 AM
Bell's Avatar
Bell
Hardy har har!!! Very funny. :
Wait a minute... Hmmmmmm, I wonder...
Be right back...
Old Dec 17, 2007 | 12:01 PM
DALE C's Avatar
DALE C
B2809 is a service column lock code. I am sure it just set due to the low battery voltage with the key in.
Old Dec 17, 2007 | 01:06 PM
tstar's Avatar
tstar
Hey cool! Thanx!!!
Where did you find that?
Old Aug 25, 2023 | 09:50 PM
Ed Ramsey's Avatar
Ed Ramsey
Hey, guys. I have the B2809 Code in my 2002 Convertible. Just installed the LMC5 Module. Installed a New 3 year battery. I don't have the Pull key, wait 10 seconds message. But I do have the Service column lock message. I have rechecked my installation and checked fuse 23. "All okay" I haven't installed the brown wire yet. Any ideas?? Thanks in advance.
Old Aug 26, 2023 | 09:57 AM
rrwirsi's Avatar
rrwirsi
Install the Brown Wire. It fixed my issue.
Old Aug 26, 2023 | 11:47 AM
Ed Ramsey's Avatar
Ed Ramsey
I'll give it a go. I'll let you know if it fixes it. finger crossed.
Old Apr 14, 2024 | 12:40 PM
fitten2go's Avatar
fitten2go
Navigator
Did the Brown Wire Mod fix it? It didn't fix my "Service Column Lock" issue. I still get that message at every single start up (though everything still works normally).
To Secret DTC Code
