Wont Crank,code B2723
Old Dec 17, 2007 | 03:17 PM
GBOYLE's Avatar
GBOYLE
1st Gear
Default Wont Crank,code B2723
Anybody Have The Pinpoint Tests For A Code B2723.i Tested The Tdr Relay.it Is Good.i Am Not Getting The Ground Signal
From The Bcm To Energize The Tdr.i Suspect The Key Is Not Being Read.thank You
Old Dec 17, 2007 | 04:49 PM
Oldvetter's Avatar
Oldvetter
You need to fill out your profile for your car year.
I pulled 2002 for that code, here it is:
Document ID# 680097
2002 Chevrolet Corvette
DTC B2723
Circuit Description
The body control module (BCM) supplies a 5 volt signal and a ground circuit for the PASS-Key® system. This allows the BCM to detect PASS-Key® resistance values. Inserting the PASS-Key® (with resistor pellet) in the ignition lock cylinder completes the PASS-Key® circuit. Contacts in the ignition lock cylinder mate with the pellet contacts. The BCM compares the resistance value of the key pellet to the valid resistance programmed into the BCM. If the proper resistance value is read, the BCM allows the following functions to occur:
The theft deterrent relay to energize.
The steering column to unlock.
The BCM sends a message through the serial data line to the powertrain control module (PCM) to allow fuel delivery to occur.
If the resistance value is incorrect, a malfunction is present and a DTC will set.
Conditions for Setting the DTC
The voltage level sampled at the BCMs PASS-Key® signal circuit is incorrect, signaling that an invalid PASS-Key® resistance was detected, and a short or an open is present.
This condition must be present for 1 second.
Action Taken When the DTC Sets
The BCM stores DTC B2723 in memory.
The BCM sends a message to the instrument cluster to illuminate the SECURITY indicator.
The BCM disables the theft deterrent relay.
The PCM will not allow fuel delivery to occur.
The BCM disables sampling of the PASS-Key® resistance for a time-out period of 3 minutes.
The steering column remains in the locked position.
Conditions for Clearing the DTC
This DTC requires an ignition cycle in order to change from current to history.
The BCM detects a valid PASS-Key® resistance value on the PASS-Key® signal circuit.
A history DTC will clear after 50 consecutive ignition cycles if the condition for the malfunction is no longer present.
Use the instrument panel cluster (IPC) clearing DTCs feature.
Use a scan tool.
Diagnostic Aids
If the key resistor pellet is incorrect, there will be no BCM outputs to the theft deterrent relay or to the PCM. This state will last about 3 minutes. If a key is inserted, or the ignition is turned ON again before the 3 minute time frame is complete, the timer will reset to 3 minutes. Disconnecting the battery will not clear the timer sequence, but the timer will reset to 3 minutes when the battery power is restored. Even if a proper key is inserted during one of the time periods, the vehicle will not start until the total time period has elapsed.
If there is a short between the PASS-Key® signal and ground circuit, or a short to ground on the PASS-Key® signal circuit, the vehicle will exhibit a no crank condition.
Test Description
The number below refers to the step number on the diagnostic table.
This test verifies the integrity of the key resistor circuits between the ignition switch and the BCM.
Step
Action
Yes
No
Schematic Reference: Theft Deterrent System Schematics
Connector End View Reference: Theft Deterrent System Connector End Views
1
Did you perform the Theft Deterrent Diagnostic System Check?
Go to Step 2
Go to Diagnostic System Check - Theft Deterrent
2
Install a scan tool.
Turn ON the ignition with the ignition OFF.
Select the BCM Display DTCs function on the scan tool.
Does the scan tool display B2723 as a current DTC?
Go to Step 3
Go to Testing for Intermittent and Poor Connections in Wiring Systems
3
Inspect the ignition key for dirt or obvious damage.
Does the ignition key appear dirty or damaged?
Go to Step 8
Go to Step 4
4
Turn OFF the ignition.
Disconnect the ignition lock cylinder connector.
Connect a J 35628-A Vats/Passkey Interrogator using terminal adapters from a J 35616-A to the key resistor input circuit and key resistor reference ground circuit.
Insert the ignition key into the key code reader on the J 35628-A and note the code on the LCD display.
Turn the rotary switch on the J 35628-A to the same code number as the ignition key.
Attempt to start the vehicle.
Does the vehicle start?
Go to Step 7
Go to Step 5
5
Test the following circuits for an open or a short to voltage:
The key resistor input circuit
The key resistor reference ground circuit
Did you find and correct the condition?
Go to Step 11
Go to Step 6
6
Inspect for poor connections at the harness connector of the BCM. Refer to Testing for Intermittent and Poor Connections and Connector Repairs in Wiring Systems.
Go to Step 11
Go to Step 10
7
Inspect for poor connections at the harness connector of the ignition lock cylinder. Refer to Testing for Intermittent and Poor Connections and Connector Repairs in Wiring Systems.
Go to Step 11
Go to Step 9
8
Clean or replace the ignition key as necessary. Refer to Replacing Keys .
Did you complete the procedure?
Go to Step 11
9
Replace the ignition switch lock cylinder. Refer to Ignition Switch Lock Cylinder Replacement in Instrument Panel, Gages and Console.
Did you complete the replacement?
Go to Step 11
10
Important
When replacing the BCM, perform the relearn procedure. Refer to Body Control Module (BCM) Programming/RPO Configuration in Body Control System.
Replace the BCM. Refer to Body Control Module Replacement in Body Control System.
Did you complete the repair?
Go to Step 11
11
Use the scan tool in order to clear the DTCs.
Operate the vehicle within the Conditions for Running the DTC as specified in the supporting text.
Does the DTC reset?
Go to Step 2
System OK
